Cayenne Diesel Oil Consumption
Hello Guys,
3 weeks ago I had my oil changed, I noticed one bar was down since the oil change and now its another bar.. I don't have a dipstick to check the level, Should i be worried? or just add some oil till it reaches the top bar
Ronan, if They used The suction method what are The pros And The cons? If drain plug wasnt tight enough I can spot some OiL in my Garage Floor no?
Down side to extraction method is the tech may not get all of the old oil out. The plug should be fine with extraction, however if traditional drain was used then maybe the plug isn't tight enough.
I'd still call the tech/dealer and not drive until resolved due to the amount lost in a short time period.
Another reason could be a bad seal. Look in engine bay (with cover off) to see if any oil is present outside of engine. Down side to extraction method is the tech may not get all of the old oil out. The plug should be fine with extraction, however if traditional drain was used then maybe the plug isn't tight enough. I'd still call the tech/dealer and not drive until resolved due to the amount lost in a short time period.
dealers I hear only do extraction. Find Gnat's diy thread or his signature for how to change your oil if you want to do it.
Yes found it, Good info, My Dealer charges for OiL changes around $220 I Think its good, but I'll check on monday with my S.A about The oil
Not a drop burned over 20k here. Any oil loss should be a bad sign, but Porsche has continually claimed its normal and refuses to do anything until it's just obscene (like a quart every few hundred miles or some other BS). What's sad is that the owners just suck it up and accept that garbage. It is equally ridiculous that they don't give us a physical dipstick.
My first fill dropped a bar pretty quickly, but never moved after that. My assumption was that I put less oil in than I should have and it getting forced into the filter is what caused the level to drop. Since then I've had a full 8 liters put in and the gauge has never changed between OCIs since then.
Unless it's really bad you won't see oil on the ground if there is a leak. You need to drop the belly pans.
Good morning guys, took The CD to service Tuesday, they told me that piwis is more accurate on reading OiL, first I had 3 bars down, yesterday I got The CD back with 2 bars And now this morning again 2 bars is this something normal? Thanks all
And that pic is not "down", that is exactly where it should be. There is still room for more oil before you get into an over fill situation, but you also have plenty of room before you get into an under fill situation too.
I have not heard anyone report the level going up, but I guess it is possible that if your fill is right at the border of the two indicators it could bounce back and forth in the right circumstances. The solution would be to add a tad more oil to get it off the border.
My first DIY fill was exactly as your pic shows and then after a few miles it dropped to 1 bar. As it stayed that way until the next OCI interval I didn't worry about it. Since then I just dump in the full* 8 liters and it stays at 4 bars on the gauge.
* Unless you leave each bottle there for a long time it's not really a full liter you are getting out of the bottle which is enough to keep it from an over fill situation in this case.
I don't understand the bold part. Are you saying when you picked it up it looked like what is shown in the pic and now this morning it still looks like that? And that pic is not "down", that is exactly where it should be. There is still room for more oil before you get into an over fill situation, but you also have plenty of room before you get into an under fill situation too. I have not heard anyone report the level going up, but I guess it is possible that if your fill is right at the border of the two indicators it could bounce back and forth in the right circumstances. The solution would be to add a tad more oil to get it off the border. My first DIY fill was exactly as your pic shows and then after a few miles it dropped to 1 bar. As it stayed that way until the next OCI interval I didn't worry about it. Since then I just dump in the full* 8 liters and it stays at 4 bars on the gauge. * Unless you leave each bottle there for a long time it's not really a full liter you are getting out of the bottle which is enough to keep it from an over fill situation in this case.
Today its showing again 3 bars.. But if this is normal I'm cool just wanted to make sure if I didnt need some extra oil
I wouldn't call it normal since I've never heard of it going up without adding oil, it's just my theory that it could be possible with the right oil level and alignment of the stars.
Sounds like you've got plenty of headroom so add 1/8-1/4 of a liter and see if that doesn't settle it down.
I wouldn't call it normal since I've never heard of it going up without adding oil, it's just my theory that it could be possible with the right oil level and alignment of the stars. Sounds like you've got plenty of headroom so add 1/8-1/4 of a liter and see if that doesn't settle it down.
Sure I'll do that tomorrow, Thanks Dave
