Front Parking Sensors at Stoplight/Sign??
Old Oct 1, 2015 | 01:21 PM
jab23's Avatar
jab23 has a spectacular aura aboutjab23 has a spectacular aura about
Hi All,
Did some cursory searching and haven't braved the manual yet, but one of my biggest annoyances in my 14 GTS is that the front parking sensors go off when there is a car in front of you at a stop. I'm not that close! Is there a way to adjust the sensitivity? Happens all of the time and manually turning it off is not only a pain, but I forget to turn it back on during that trip. Once it's off, it's off until you start the car next.
Thanks!
Old Oct 2, 2015 | 05:33 AM
Robotpedlr's Avatar
Robotpedlr is infamous around these partsRobotpedlr is infamous around these parts
I don't think you can adjust it. My manual says it kicks on at 31.5 inches (I have a 2015).
If yours cones on further out then that, I would check your manual and maybe have it looked at during your next service. If that is the distance yours operates at also, you can just try stopping out a little further. I find 31" is pretty close and seems like a reasonable range.
Old Oct 2, 2015 | 06:51 AM
jab23's Avatar
Thanks. Yeah, I eyeballed the manual last night and mine is 47 inches. No obvious adjustment available. Guess they tightened it up a bit on the 2015. I don't feel that close to cars in front of me. Happened again at the coffee drive through this morning. Now it's just on my mind, so it's more annoying.
Between this and the ticking noise at idle, I want to pull my hair out. Then I just go WOT for a second and the sound of the exhaust makes everything right with the world again!
Old Oct 2, 2015 | 08:40 AM
Robotpedlr's Avatar
With an eHybrid the only ticking noise I hear at idle is my watch.
Lowtush
Jan 25, 2022 10:48 AM
Enemy
Nov 10, 2015 08:01 AM
Konea420
Aug 25, 2015 09:44 AM
