Cold shift from reverse to first
Old Dec 24, 2016 | 05:47 AM
0Dogg's Avatar
0Dogg is infamous around these parts
Does anyone recognize or experience the following symptom? Typically, on my first drive of the day I have an odd issue with a 1-2 second lag when I back out of my driveway. When I shift to D, 1st engages fine with not audible sounds, etc. But when I hit the gas, the vehicle doesn't accelerate immediately...it shows no ill effects between other gears and usually doesn't do it again unless it sits for a while. Thanks!
Old Dec 24, 2016 | 07:42 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
On most automatic transmissions this would be a sign that the fluid level is low. Has the transmission been serviced lately? Any sign of leaks?
Old Dec 25, 2016 | 07:25 AM
wkearney99's Avatar
wkearney99 has a spectacular aura aboutwkearney99 has a spectacular aura about
That and does it sit parked on an incline?
It helps greatly if you include the year and model as not all have the same engines, transmissions or other features.
Old Dec 26, 2016 | 08:08 AM
Boeing Driver's Avatar
Boeing Driver is infamous around these parts
I have a 2011 958. Mine does similar, sometimes a 1-2 second delay from the time I put it in drive till the time it actually engages.
Old Dec 26, 2016 | 05:50 PM
wkearney99's Avatar
My '06 Jeep would do this and it was usually attributable to low fluid or an issue with a transmission filter. Their initial design had issues with how the fluid drained out of the torque converter. There was a TSB for it.
I've no idea if something similar is an issue with the Cayenne, but without a year and model it's even harder to guess.
