Door handle emergency key cap
Old Apr 16, 2017 | 10:00 PM
Matt911's Avatar
Matt911 is infamous around these parts
I had to use the emergency key to unlock the car door today. So I inserted the key under the door handle cap and pulled the cap and unlocked the car. But when I tried to put the cap back on it won't stay put I can pull it with the slightest force. Is there a trick or something to install the cap back on ?
Old Apr 18, 2017 | 06:28 AM
Matt911's Avatar
Nevermind, the cap inside trim to hold it is broken thats why it won't stay hold.
Old Apr 18, 2017 | 11:52 AM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
One time use design? Unfortunate since I'm sure the new one doesn't come painted (but I'd be delighted to be proven wrong on that assumption..)
Old Apr 18, 2017 | 02:50 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
not a one time design. for some reason my remote unlock/lock buttons wont work sometimes and ive had to manually unlock and pull the cap off 4-5 times now. when putting it back on, you have to hook/slide one side on first before you push/snap the other side in. op probably just tried to snap the cover back on all at once and broke the tab. mines still intact after removing and re-installing many times.
Old Apr 18, 2017 | 11:29 PM
Matt911's Avatar
Yes correct it can be pulled multiple times, but I didn't know any better so i just shoved the key and pull the crap out of it and voila broken. And I ordered the part it comes in primer unfortunately
Old Apr 20, 2017 | 01:55 PM
TJtheDJ's Avatar
TJtheDJ is infamous around these parts
This happened to me back in November twice in one week after buying my Cayenne. I since put new batteries in BOTH keys to address the issue. It hasn't happened since.
