Anyone change their coolant on a 958?
Old Oct 8, 2017 | 11:18 PM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
Looking for some help on this topic at 160k on the odometer and figured the lifetime fluid is done.
I was only able to get about 1/2 gallon of old coolant from the radiator. I could not find a drain plug on the bottom as described in the 955/957 instructions. The lower radiator hose was very difficult to remove and disconnect, I removed it just below the intake and pumped out the old coolant.
This is not 4 to 5 gallons and described in the 955/957 DIY.
Anyone familiar with a pressurized radiator after the system is open?
I have done Airlift pressure bleed/fill on my 996 and seen the write up for the 955/957 or refilling won’t be an issue
Old Oct 14, 2017 | 09:33 PM
jayi836's Avatar
I have had the CTT almost 3 months and just purchased the service manual
This hose was tough to get to so I pumped the old coolant out.
No drain on the 958 Radiator have to loosen this hose another PITA.Never got it off, pumped out the fluid .
This is the oil cooler, remove these hoses too again what a PITA!
Well I get to use this thing again, Purchased for my 996
I was able to replace 5 liters of coolant.
