Coolant leak from the cap at high speeds?
Old Aug 7, 2018 | 03:08 PM
AgentSmith's Avatar
AgentSmith is infamous around these parts
Hi, guys! I've had problems with the cooling system of my '13 Cayenne Diesel for some time. First, had to replace some of the plastic pipes, since coolant starting pouring from the car. Then, I still had a leak under the front passenger. Turned out the tank and cap needed replacing. This seemed to fix my problems until I had the chance to drive the car faster for 20 minutes at 90-120 mph. Coolant started coming out of the cap. I tried the test two times - with the new cap I lost some, but not all. I decided to try the old cap, and pretty much my whole tank leaked out (had to pour in 2 liters of 50:50 mix to get the proper level back). I replaced the lost coolant, and drove the car around the city at normal speeds, not exceeding 70 mph - not a single drop from the cap. What could be the problem here? I cannot grasp why it only happens at highway speeds.
Old Aug 8, 2018 | 03:51 PM
AgentSmith's Avatar
Guess I baffled you as much as my mechanic
Old Aug 9, 2018 | 08:01 AM
wkearney99's Avatar
wkearney99 has a spectacular aura aboutwkearney99 has a spectacular aura about
Have you checked there's no combustion gases in the coolant? As in, a crack somewhere forcing gases into the cooling system, causing enough pressure to cause the coolant to be forced out of the tank. I've never used one, for neither gas nor diesel, so I can't say which ones work.
That and how's the water pump?
Old Aug 9, 2018 | 08:05 AM
AgentSmith's Avatar
Water pump should be OK, I told the mechanic to check. It is not leaking, temp is OK when there is coolant in the system. Not sure what other signs to look for.
Thanks for the combustion gases test suggestion, seems to be the only option now.
turbo_secret
Dec 21, 2019 05:49 PM
wa2fast
Jul 10, 2012 05:23 PM
dog4delta
May 26, 2009 07:52 PM
seung
Aug 29, 2007 09:54 PM
kzrsoize
Jun 15, 2007 07:50 AM
