Cayenne Turbo All Cayenne Turbo model topics
955 Turbo Y Intake replacement
Old Apr 4, 2015 | 08:32 PM
b52guy's Avatar
b52guy is infamous around these parts
I believe my Y tube is cracked (Durametric throwing an error). I'm looking to replace it, found this silcone tube from Porscheshop in the UK. I think I'm going to try it. Anyone else heard of it or seen it used??
Old Apr 5, 2015 | 08:50 AM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
Nice ! I have seen these as well but dont remember the link , can you send it to me please ?
Old Apr 5, 2015 | 09:19 AM
b52guy's Avatar
I ordered it last night.
http://www.porscheshop.co.uk/acatalo...induction.html
Old Apr 5, 2015 | 11:50 AM
Very good , please post photos (open new thread ) when you install it .
Old Apr 6, 2015 | 05:58 PM
jdubbya's Avatar
jdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to behold
So I wonder if that replaces the two hump hoses between the Y and intake pipes at the same time? Kinda looks like it from the pic but there aren't any real dimensions on the site.
Old Apr 6, 2015 | 05:59 PM
b52guy's Avatar
That's what I've read. It basically eliminates 2 clamps.
Old Apr 7, 2015 | 12:19 AM
mtnrat's Avatar
mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !
A pretty good price as well. Let us know about how it fits.
Old Apr 7, 2015 | 11:44 PM
ciaka's Avatar
Did they have other colors than blue? I am tempted to redo my valve covers and coil packs to be silver with red, so blue would be the black sheep in that part of the car.
Old Apr 18, 2015 | 01:40 AM
jdubbya's Avatar
I'd really be interested in some more info on this when you get it in hand. Like what size all the openings are and if it has a way to mount the MAP sensor in the top. It looks like you will have to clamp the vacuum fitting on the bottom which isn't a big deal since I seem to always have issues with the stock fitting anyway.
If you wouldn't mind snapping some pics and dimensions I'd appreciate it.
Thanks!!
John
Looking around tonight I stumbled on this but it's not really 90 deg but close. Would have to adapt for the vacuum fitting and the MAP sensor. Could be a pretty cheap start though.
http://www.cxracing.com/mm5/merchant...ry_Code=PIP300
Old Apr 18, 2015 | 12:21 PM
hahnmgh63's Avatar
hahnmgh63 is infamous around these parts
The stock Y-pipe can be had for cheap to replace but that looks like a nice piece depending on how the MAP sensor is mounted. I would also like to see the inside to see if the air is guided anyways.
Old Sep 26, 2015 | 01:58 PM
BG305's Avatar
BG305 is infamous around these parts
So I noticed I had a boost leak from the Y pipe and decided to order this silicone replacement. The first thing I notice is it does not come with a place to mount the MAF censor. I also noticed a leak on the left side joint that comes off of the intercooler. I should have it installed on Monday.
Boost leak here.
Old Sep 28, 2015 | 06:43 PM
BG305's Avatar
Well I tightened things up and replaced O-rings. Let's see if the leaks are taken car of. I received no response from the company for the Y pipe with no MAF port. It's in so we will see if I have any problems with the MAF.
Old Oct 4, 2015 | 07:30 PM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
You mean the MAP sensor. Did you use a bolt/nut to keep it secured in the tube?
FYI, I had this made by a local performance fabricator when I had my CTT. Flange was welded on for the MAP sensor. This could be replicated pretty easily...maybe not the whole thing (I had a full intercooler and piping kit made) but sure the y-pipe. Not much in cost for the parts at all.
Old Oct 11, 2015 | 04:56 PM
BG305's Avatar
You are correct sir. MAP. I remember seeing your build, it's sweet. It's a little harder for me to get a custom build since the pig is in Costa Rica.
COBB Tuning
Jan 1, 2025 09:02 AM
Jun 10, 2017 07:45 PM
Fuzzo
Cayenne 955/957
Aug 26, 2015 09:45 AM
Lucid Moment
Aug 20, 2015 02:22 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
