Just bought a used Cayenne, need some help!!!
Old Aug 29, 2009 | 11:39 AM
boostedtwin's Avatar
boostedtwin is a glorious beacon of lightboostedtwin is a glorious beacon of lightboostedtwin is a glorious beacon of lightboostedtwin is a glorious beacon of lightboostedtwin is a glorious beacon of lightboostedtwin is a glorious beacon of light
Forgot to mention, added LED to the whole interior of the car replacing the "yellow bulbs". Looks 1000% better.
Old Aug 29, 2009 | 12:19 PM
ONE234's Avatar
ONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud of
how easy was this to do?
i have gambella white dials and the bulbs there are all white, and i wanted to change the rest of the bulbs if possible, did you change the steering wheel control lights also? i would be interested to know how this is done.
thank you.
Old Aug 29, 2009 | 12:36 PM
No, I did not go that far. I did all the lighting for the doors, under the seats, mirrors, trunk, roof, under dash. It's really easy. A few clicks and it's done. It's a lot of bulbs. The Cayenne has bulbs everywhere. It's worth IMO.
Old Aug 29, 2009 | 01:21 PM
Old Aug 29, 2009 | 03:33 PM
ONE234's Avatar
ok, with LED bulbs does that not through up an error or check bulb light, or is that only for driving lights?
i know that when i tried to change the rear number plate festoon bulbs it through up a bulb out light on the dash?
Old Aug 29, 2009 | 06:03 PM
No fault codes. Plug-&-play.
Old Aug 30, 2009 | 06:31 AM
Twincharge's Avatar
Twincharge is infamous around these parts
thank you.
I know the mod you were thinking of, I did this mod on a GOLF IV a while back. Replaced all the main blue LEDs with YELLOW items. An easy mod if you are good with a solering iron like me.
Old Sep 1, 2009 | 09:51 AM
ny2nj's Avatar
ny2nj is infamous around these parts
Where did you get your LED's...also your clear corner light from?
Car looks good btw!!
Old Sep 1, 2009 | 02:01 PM
Clear corners from Suncoast and LED from a local seller. I can get his contact info if you need it. I'm sure he can ship the LED's. They are costly though, like $10-$15 a piece. I spent I think close to $300 for the whole car.
Old Feb 3, 2011 | 01:45 PM
toshii's Avatar
toshii is infamous around these parts
Originally Posted by lovethesport
22 are a must
they are deff a must. i just put 22" turbo style wheels on mine and it looks great. ill post a pic later when i get a chance
Old Mar 10, 2011 | 10:30 AM
cburnette1007's Avatar
cburnette1007 is infamous around these parts
Cayenne
Now that you have had the 22 inch wheels for over a year now how do you like them?/ Have you had any problems?
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
dgreen78
Feb 29, 2016 11:28 PM
Yellopeter
Cayenne
Oct 9, 2015 11:20 AM
arhim22
Sep 7, 2015 08:49 PM
