Spacer Help Needed
Old Dec 29, 2013 | 01:12 PM
mikhail1's Avatar
mikhail1 is infamous around these parts
Spacer Help Needed
I have a 2008 Base Model Cayenne V6 with 20" rims, tire size 275/45/20
I want to run 15mm spacers on front and 18mm on rear.
Would this be safe and ok? I just want the tires to basically be flush with the frame.
Anyone's help/advice would be greatly appreciated.
Thank you!!!! - Mikhail
Old Dec 30, 2013 | 05:42 PM
MikeL's Avatar
MikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of lightMikeL is a glorious beacon of light
yes you will be fine, just make sure you get hubcentric spacers as well as the longer correct length bolts. achtuning.com is a great place that sells everything you need.
Old Dec 30, 2013 | 07:36 PM
carreracup03's Avatar
carreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the roughcarreracup03 is a jewel in the rough
I have some porsche fit 15mm hubcentric with extended bolts for sale.
Old Dec 30, 2013 | 08:30 PM
mikhail1's Avatar
How much? Sent you a PM.
Old Dec 30, 2013 | 10:49 PM
mikhail1's Avatar
Will it stick out past fender
MIKEL:
will the 15mm spacer in the front cause the tires to stick out past the frame you think?
Old Jan 10, 2014 | 03:47 PM
MikeL's Avatar
Originally Posted by mikhail1
MIKEL:
I know it'll work on a 958 and not stick out, not sure if it'll work on the 955/57.
VGLNTE1
Aug 24, 2015 12:23 PM
00aston
Aug 24, 2015 09:29 AM
Fadi
Aug 21, 2015 03:43 AM
cab83_750
Aug 19, 2015 12:37 PM
