what to look out for on a 2008 turbo with
Old May 12, 2014 | 06:56 AM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
I know i'll need a ppi but what's the common stuff to look out for on a 2008 turbo with 100k miles? I know the coolant pipes are still plastic but better design and no known failures? PDCC/air susp. failures common? Driveshaft guibo? Waterpump? I'm not concerned about normal wear/tear items such as brakes/tires/coilpack/plugs. Thanks.
Old May 12, 2014 | 07:57 PM
Skigod9's Avatar
Skigod9 is infamous around these parts
2008 has revised coolant pipes, and don't have the problems others had
Old May 21, 2014 | 10:28 AM
Adam5oh's Avatar
Adam5oh is infamous around these parts
When we bought our 08 with 83k on it it needed a water pump. Had the driveshaft mount go out while towing the boat a few weeks ago, so that problem is still around apparently.
Old May 22, 2014 | 12:36 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
The 08' still has a coolant fitting in the back of engine that will pop out over time. It needs pinning or the OEM updated part (requires engine removal). I have heard it has 1 plastic pipe as well under the intake manny.
Old May 23, 2014 | 10:02 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
To me the most important thing is complete up to date maintenance. If the vehicle has been properly maintained from the beginning, it will likely continue to be a very dependable vehicle. If not, it could be very costly to bring up to date and do the repairs and upgrades that are necessary at, and by, 100,000 miles.
Old May 23, 2014 | 10:59 PM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
115k here and runs like a champ, this is no pos escalade with that many miles.
Old Jun 5, 2014 | 11:43 AM
drewcwsj's Avatar
drewcwsj is infamous around these parts
I just pulled the engine on my '08 CTT to replace the rear coolant distribution manifold - the glue failed that holds a pipe stub in the manifold. While it was out I also replaced all the coolant hoses, the thermostat housing (has two glued in pipes), thermostat and replaced the single coolant tube/tee with a new aluminum version.
The new manifold from Porsche is no longer glued but threaded and lock nutted. It is never coming out.
ID:	382857   Click image for larger version
2lflat4
Nov 18, 2019 05:05 PM
Mackchacha
Jul 9, 2019 11:03 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
STAGGERED M3
Sep 11, 2015 12:00 AM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
