cayenne s 2005 transmission
Old Oct 30, 2014 | 07:51 AM
ray124's Avatar
ray124 is infamous around these parts
Hi.
I own a cayenne s 2005 automatic 6 speeds.
I've been experiencing some troubles with the shifting. After driving for 15 minutes or more on the 6th speed (highway) then going back of the road the transmission sometimes struggles to shift on 4th speed (high rpm then when it shifts i feel a sock) and sometimes after shifting it blocks on the 4th speed and i have to restart it.
Today it happened. After restarting the cr then on my dashboard instead of seeing the regular D2, D3, D4 etc. I had only a D in a yellow square (nornally D2... jn yellow and not in a square)
Did someobe already experience such a problem or knows what it is exactly?
Thank you for your time.
Have a nice day
Ray
Old Oct 31, 2014 | 09:09 AM
BG305's Avatar
BG305 is infamous around these parts
I believe that most shifting problems on these trannies stem from the valve body. If you are going to try something to correct the tranny problems this is the easiest and least expensive thing to do.
Old Oct 31, 2014 | 10:54 AM
ray124's Avatar
Do tou know to wich valve it is related?
Old Oct 31, 2014 | 10:59 AM
BG305's Avatar
I have no clue but I think it's best to just replace those whole unit.
Old Oct 31, 2014 | 12:20 PM
cordsig79's Avatar
cordsig79 has a spectacular aura aboutcordsig79 has a spectacular aura about
Revmax has a great one, call them and give them your VIN. Buy the remanufactured Valve body(comes with transimission filter/gasket, you need to buy 7-8 ATF.).
350 core charge upon return.
I just did this after 30k of rough shifts etc..........I am at 170k miles and still enjoying my 2006.
Old Oct 31, 2014 | 01:11 PM
BG305's Avatar
I also went with revmax although the filter and pan gasket were to included.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
dgreen78
Feb 29, 2016 11:28 PM
HIGHcard
Sep 24, 2015 08:09 PM
the997dude
Sep 2, 2015 08:51 PM
