Stupid Mistake Measuring Voltage - Won't Start Now
Old Oct 18, 2016 | 03:12 PM
compositeguy's Avatar
compositeguy is infamous around these parts
I had the connectors in the multimeter hooked up wrong and was attempting to measure the battery voltage via the engine "probes". Unfortunately, I got a spark. I realized I had the hookups wrong on the multimeter and adjusted them. I got 11.9V, which is low. But then the engine won't start at all.
Maybe its just a fuse?
EDIT: Checked the fuses in the engine compartment and they were all good. I didn't see any in the door compartment that might be relevant.
Also checked the voltage again at it was 10.9V. So maybe the battery just totally (and instantly) crapped out? I am used to batteries dying in an more gradual manner. Maybe that short killed a cell or something?
Old Oct 21, 2016 | 08:32 PM
jdubbya's Avatar
jdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to behold
I would have thought it would blow the fuse in the meter before doing any real damage to the car or battery. But I'm no sparktrician either.
As is the usual advice around these parts, if you suspect anything to do with the battery get it load tested.
Old Oct 22, 2016 | 01:12 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
At 10.9V the battery is basically dead. Time for a new one. And I'm sure that Porsche has a base-level voltage cutoff - where below a certain voltage the modules in the car shut themselves down to protect themselves against low voltage (which can cause excess current draw and overheating.)
Old Oct 22, 2016 | 05:56 PM
I replaced the battery and all good. I guess it was just a coincidence that it died exactly at the same time I hooked up the multimeter incorrectly. Just odd because batteries usually give a bit more warning.
I did get a "4 wheel drive error" right before the battery died, which is what prompted the voltage test. So there was some warning, but no hard starting.
Old Oct 24, 2016 | 06:31 PM
jdubbya's Avatar
My battery didn't give me any warning either. Went to start it one Sunday morning and nothing. These cars are very sensitive to a less than perfect battery. Lot's of documentation with all kinds of oddball symptoms showing up when the battery is on it's way out or not at full charge.
