Left low beam not working
Old Feb 1, 2018 | 03:05 AM
Dahl0113's Avatar
Dahl0113 is infamous around these parts
Dear Sirs,
Hope you can help. This is a 2006 Cayenne Turbo S. Left headlight low beam stopped working and obviously I thought the xenon lamp was out. Ordered new ones and swapped both sides. Still no light on Left side. Fuse, no 35 is good. Cant see if their is another fuse relevant for this? Also, could it be a relay that is bad? But right side works fine so that would require a separet relay. I have pulled the relays I can find and that makes no difference. Would appreciate any thoughts on this. Thanks , Martin
Old Feb 1, 2018 | 04:09 AM
Dahl0113's Avatar
Cont.
so I have spent sime time on the forums and from what I can tell I should also check if the connector goes all the way in as it seems to have a tendency to wear and dislocate. Will try to connect it outside the holder to see if that does it. Martin
Old Feb 1, 2018 | 08:40 AM
Dahl0113's Avatar
Swapped the driveunits between Left and right and that was the issue. So now I need to source that printer circuit board or else swap the whole headlight.
Btw, sorry for the poor english. Native Swedish.
Best, Martin
Old Feb 26, 2018 | 07:20 AM
hichamaziz's Avatar
hichamaziz is infamous around these parts
it must be done by expert
Old Feb 26, 2018 | 07:25 AM
Dahl0113's Avatar
Case closed
Thanks for feedback.
Got a second hand drive unit which fixed the problem. Car sold - moved to a 2013 Panamera GTS. Happy as a kid on Christmas!
Martin
Jetman 7
Nov 1, 2022 03:38 PM
Jdm_dsao
Oct 22, 2016 07:28 PM
