As long as you have heated steering and the other does too or you don't and the other doesn't. As I recall, there isn't much to do. Just take old off, put new on.
If you're going to heated from non heated, you need the clock spring and coding by PWIS or maybe x431 can do it.
Does anyone know if I remove the wheel from my 2014 958 and replace it with the newer style multi-function wheel with the GPS adapter, can I still use my airbag from the 2014 or do I need to upgrade that as well?
2013 958 Cayenne multi-function heated steering wheel retro fit
Now my car is a steering wheel without multifunction function.
To install the multifunction function and the heating function,
I bought a clock spring and a multi-function heated steering wheel.
After installation, I coded with an autel scanner, and the heating function worked!!
However, the remote control switch on the left side of the steering wheel does not work, and the DTC warning light turns on..
The heating function also doesn't work sometimes (have to press the switch a few times for it to work)
Looking at the articles above, it seems that I have to do wiring work, and it seems that I have to code,
Can someone give me some info?
thanks, please help...
