Is carwash soap hard on wax?
In touch-less car washes, who's doing all the agitation required to remove all the dirt and grime? The answer is harsh chemicals. Ever notice what those water spot looking things are on the black rubber moldings after your car is dried from a car wash? It's the harsh chemicals used to clean your finish. So to answer your question, soap used in both car washes that use brushes or are touch-less, is VERY aggressive and will prematurely wear down the wax you have on your finish. Sorry to be the bearer of bad news
First, the strength of the wash solution is a key factor. The PH of the wash solution must be neutral. A wash solution that is to harsh or high in surfactants will prematurely "wash" the wax from the surface, and this applies to all waxes. All you need is Car Shampoo that is PH balanced.
Wheeler
Sep 22, 2015 08:02 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
