need some detailing tips
Old Jul 27, 2008 | 08:09 PM
Zaks's Avatar
Zaks is infamous around these partsZaks is infamous around these parts
Originally Posted by 65vetteC6
one more question, I have a C2 corvette also that has been repainted and I was wondering what polish to use on that?
Yea, like Phil said, whatever the paint you should just start off light and move up as necessary.. the only thing I have to add is that, if the re-paint was cc only, you're not polishing for hours without results because the new cc is covering the actual swirl marks.. I polished out my mother's car the other day and the shop that did a re-spray because of some damage only sprayed the trunk with cc after sanding it down a bit, so not only does it have tons of orange peel now, it's also covered with swirls which 3 passes of 105/PFW didn't touch, leading me to believe they're all under the cc... just so you know in case you find yourself polishing a section 10 times with no visible improvements...
Old Jul 27, 2008 | 08:22 PM
65vetteC6's Avatar
65vetteC6 is infamous around these parts
What is CC
And is there any difference between CCS black red or blue pads?
Old Jul 27, 2008 | 08:25 PM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
red will be the softest pad then black then blue, they are really close ...
red should be for wax/sealant.
i believe cc is clear coat.
Old Jul 27, 2008 | 08:29 PM
Zaks's Avatar
^^ yea I meant clear coat sorry...
Old Jul 27, 2008 | 08:32 PM
65vetteC6's Avatar
Ok thanks yea a friend repainted so I dont think he just resprayed cc. I was looking at your PC kit on Detailers Domain. It comes with a black pad. Would I be albe to switch that with the red? Also I am in North Jersey, If I wanted this stuff by friday when would i have to order through you by? (considering its ground shipping)
Old Jul 27, 2008 | 08:45 PM
Zaks's Avatar
You can use black on the PC to apply a sealant/wax... although I use it with finishing polishes to refine the paint as a final step and I never apply LSPs with the machine, I'm positive you can do it as it has pretty much no cutting ability...
Old Jul 29, 2008 | 07:57 PM
65vetteC6's Avatar
Is there a certain amount of time I need to wait before polishing paint that has been repainted recently?
Old Jul 29, 2008 | 08:07 PM
not on polishing but maybe on waxing.
you should speak to the body shop that painted the car. Some say you can wax immediately and some say 30 days or even longer.
Its safe to polish the car provided its a polish with no protectants them.
Old Jul 29, 2008 | 08:34 PM
65vetteC6's Avatar
ok also do i need to be carefull on the body lines of the car and the side scoops? Can I damage the paint. If your not following me let me now. Like right about the Z06 emblem where it is flat show i just leave it alone.
Old Jul 29, 2008 | 08:37 PM
I would mask the emblems and the door handles etc but with the pc you should not damage the paint. of course use your common sense.
also don't forget to take pictures.
Old Aug 1, 2008 | 09:54 PM
65vetteC6's Avatar
how much pressure should be used while doing this? Only the weight on the pc
Old Aug 1, 2008 | 09:58 PM
you can probably put some pressure while polishing the car out, probably 5-10lbs if I'm right.
Watch these videos:
http://www.detailersdomain.com/index...on=Custom&ID=3
Old Aug 2, 2008 | 11:27 AM
MoeMistry's Avatar
Premium Sponsor
With the pc, it's very simple. You put enough pressure until the pad stops spinning. Once the pad has stopped spinning, you've lost the dual-action movement. So on each setting and pad use, this pressure may be different. You basically want the pad to spin and oscillate in the random orbit pattern as well.
Old Aug 2, 2008 | 07:46 PM
65vetteC6's Avatar
OK so far so great! The SIP is doing miracle work. I have only done the rear hatch and half the roof/halo.
I just wanted to know if there is a way to see if your leaving halograms or buffer trails. Otherwise ill have to wit till the morning and hope for sun.
Also it is very hard to see swirl marks on the car. Its orange and the halogen lights arent heling to much but I think that would improve once I got the the side. The car really doesnt have much swirling.
If i do get buffer trails or halograms then when I use the Nano it should remove them right?
Old Aug 2, 2008 | 07:48 PM
do you have a halogen work light?
or even a flash on the camera you can probably check by taking some pics as well.
