Detailer's Domain introduces Menzerna PO203 with a write up
Power Finish (PO203S) - (M) this is a a one-step scratch remover polish that will remove 2500 grit, cut 3.0- gloss 3.0, Slightly more abrasive then PO 106 but produces a burnished finish (for black or dark coloured paint surfaces use as part of a duel level foam pad / polish system PO 85 RD 3.01 Super Intensive Polish) 1500 RPM - primed LC Orange / Green (mid range, high density foam (60 PPI) medium abrasive cutting action) or a White primed (softer less dense foam (70 PPI) with a light abrasive cutting action)
here is a recent detail with the use of the all new Menzerna Power Finish PO203
Got this Subie in that honestly I really didn't expect in this condition.
Swirls galore, scratches everywhere, buffer trails, burn marks you name it you got it.
So I decided to take a chance and really see what Menzerna PO203S can do. Well you can be the judge.
Customer was happy with the results.
Last step Einszett Glanz.
Products used:
Adam's Car wash
Swissvax Yellow Clay Bar with Optimum Instant Detail Spray and Gloss Enhancer
Menzerna PO203
Menzerna Top Inspection
Einszett Glanz Wax
Wheels and Tires
Swissvax Pneu
P21S Wheel Cleaner Gel
Boar’s Hair Wheel Brush
Swissvax Wheel Brush
The Spoke Brush
Foam applicator pads
Swissvax Quick Finish
Trim:
Adam's In and Out
Glass inside and out:
Adam's Glass Cleaner
Uber Glass MF Towels
Tools:
Infratech 5300
Makita 9227 Hi Speed Rotary
LC Flat White 5 inch pad
LC Flat Green 5 inch pad
Uber Waffle Weave Drying Towel
Grit Guard Bucket/Dolly
Uber Super Plush Towels
Here we go.
Before shots:
Products used:
Adam's Car wash
Menzerna PO203
Einszett Glanz Wax
Wheels and Tires
Swissvax Pneu
The Spoke Brush
Trim:
Adam's In and Out
Tools:
Infratech 5300
Here we go.
Before shots:
Before shot of the rear panel: (I am going to give you as many shots as possible to shot the imperfections)
In this rear panel I only used a white pad:
50/50 shots in angles.
Wheel Experts
Sep 2, 2015 09:04 AM
Wheel Experts
Wheels/Tires
Sep 2, 2015 09:02 AM
