CR Spotless Holiday Promotion
Old Dec 19, 2008 | 11:35 PM
MoeMistry's Avatar
Premium Sponsor
I'm in the holiday mood, so here it is. Each time I try and give you guys a great deal that shows our appreciation for your support. As most of you know, the CR Spotless is the mobile DI system that actually works. Anywhere you don't want water spots and a crystal clean surface, CR Spotless is your tool of choice.
Here it is:
OFFER ENDS DECEMBER 25TH
DIC-20, Resin Refill, and Products Retail: $449.99 + $90.00 + $105.38....$645.37
No Minimum Order: $449.99 S+H included (Save 30%) click to order
Product Description:
Hard water spots can destroy your vehicle's finish. That's why CR Spotless Water Systems created a de-ionizing system that takes out all of the minerals in your water so you can just WASH, RINSE, and WALK AWAY! That's right! With a DIC-20 Spotless Water System, you can let your car, RV, house windows, etc., air dry with no worries that hard water spots will appear. Say goodbye to towel drying and the scratches that towels and chamois can cause. You can even give your car a quick 5 minute rinse between washes to keep it looking great all the time.
Besides cars, de-ionized water is perfect for washing and SPOT-FREE rinsing of your:
  • Cars/trucks
  • RVs
  • Motorcycles
  • Boats
  • Golf Cars
  • House Windows
  • Patio Furniture
  • Decks
Customer Testimonials:
Absolutely works. Can't live without it now. Also, get the Airmax dryer from Moe at Glistening Perfection. This two system process will eliminate drying, which will also cut down on the swirling potential from the hand drying. Highly recommended.
chardonet (6speedonline)
Grab a CR system from Moe - you won't be disappointed!
MidnighTT (6speedonline)
If you don't already have the CR system...you definitely need it...fantastic!!! I love mine!!!
TUUNER (6speedonline)
I also purchased a CRspotless, and some other products, from Moe some months ago. I got the same VIP treatment that you experienced. He's a pleasure to deal with. It's great to be able to speak with someone so knowledgeable and experienced. As far as the CRspotless, I concur, it works just as advertised. It's a great time and swirl mark saver.
Paladin (Rennlist)
I received the cr spotless from Moe on saturday. Used for the first time this afternoon. In a word...incredible.Even the windows are cleaner and require no wiping off after wash. Worth every penny. Moe was a pleasure to work with....had a delivery problem and Moe offered a free refill for my inconvenience. Even my wheels are shinier. I was doubtful at first but a friend if mine kept raving about it so I decided to try it. Im glad I did.
points (Rennlist)
Got mine today. Came home from C&C and it was sitting on my doorstep. Washed both cars in less time than I ususally spend on my 997 alone.
Well worth it!! Thanks Moe.
LeNoah (6speedonline)
Got mine last week and fired it up today in conjunction with a pressure washer for initial rinse and semi-final rinse and worked incredible. Just used an open hose for the last few seconds to "flood" and basically didn't really have to wipe anything down... Thanks again Moe
INSman (6speedonline)
Package Contents:
  • DIC-20 with in-line TDS Meter
  • (2) 20" Cartridges Filled with De-Ionizing Resin
  • 4' Inlet Hose (Attaches to Hose Bib)
  • Nozzle (7 Pattern Garden Sprayer)
  • Roll of Teflon Plumber's Tape
  • Housing Wrench
  • Quick Start Guide/Warranty Card
  • einszett Perls Shampoo
  • einszett Detail Spray
  • 2 GP Australian Sheepskin Wash Mitts
  • 6 GP MicroTowels
  • 2 GP Drying Cloths
  • Bonus: Glistening Perfection 11-Step Detail Guide ($10.00 value)
Features:
  • A water de-ionization system, not a water softener
  • Removes ALL minerals and dissolved solids from the water
  • Battery operated, in-line TDS meter to monitor the water quality in and out of the system
  • Ergonomically designed cart with a padded handle
  • Easy to refill resin or replace cartridges when needed
  • Seven pattern garden hose nozzle with FLAT setting
  • 4' inlet hose to attach to hose spigot
Benefits:
  • Produces 100% pure, mineral-free de-ionized water
  • Pure water evaporates without leaving any spots behind
  • Know when it's time to change or refill the cartridges before spots appear
  • Take it anywhere; easily rolls and maneuvers with one hand
  • No need to send it back for regeneration
  • Flat spray pattern restricts water flow and increases pressure
  • Everything is supplied even the car shampoo and mitts!
System Requirements:
  • Standard Garden Hose Bib
  • Need to Restrict Water Flow to 4 Gallons Per Minute or Less with Supplied Nozzle on FLAT Pattern or Optional Pressure Washer
Expected Yield:
Input TDS Level Expected Yield (# of Gallons)
50 ppm............. 1600 gallons
100 ppm............. 800 gallons
200 ppm............. 400 gallons
400 ppm............. 200 gallons
Please PM or call 949-355-4911 if you have any questions.
For those that already purchased CR Spotless:
R6-20 Resin Refill Special click to order
Refill your DIC/DIW-20 3 times
Refill your DIC/DIW-10 6 times
Regular: $245.00
Now: $220.50 (Save 10%)
Old Dec 20, 2008 | 03:43 PM
Smoke7's Avatar
Smoke7 is infamous around these partsSmoke7 is infamous around these parts
Thats a great deal Moe, if I hadnt bought one last month this deal would really temp me. Quick question though, after about 5 or 6 rinses using it my TDS meter still reads 000, is this normal?
Old Dec 20, 2008 | 06:42 PM
MoeMistry's Avatar
Premium Sponsor
That's actually a good thing. As long as you're not getting spotting, the lower the number the better.
Old Dec 20, 2008 | 07:19 PM
Dan1's Avatar
Dan1 has a spectacular aura aboutDan1 has a spectacular aura aboutDan1 has a spectacular aura about
If you dont have a CR spotless system then you're missing out!
Old Dec 20, 2008 | 08:17 PM
Smoke7's Avatar
I figured I wanted the TDS meter to read as low as possible to make the resins last but it just seemed odd that after quite a few washes in Jersey (a place with very hard water) that it would still read 000. Good then, thanks Moe
Old Dec 21, 2008 | 08:22 AM
bbywu's Avatar
You're lucky. It means your water isn't that hard.
You can actually calculate how long your resin will last.
Measure your tap water TDS ppm.
DI output is
235,000 / TDS X cubic feet of resin = Gallons of “Spot-free Water”
The larger unit has 0.33 cubic feet of volume. In my area, my water has a TDS of about 560...So I only get 138 gallons, where as my friend across town has city processed water with a TDS of 160...he gets over 484 gallons. Big difference.
I figure I pay about 65 cents a gallon, and use about 7-10 gallons per wash. In the end...its worth it. Don't let the TDS rise more than 15-20...you'll start spotting again.
Old Dec 21, 2008 | 10:07 AM
MoeMistry's Avatar
Premium Sponsor
DI output is
Thanks for posting the technical calculations. Will come in handy for most.
Marpir821
31
Sep 26, 2015 05:29 AM
socalbreeze
Sep 11, 2015 12:37 AM
albert@velosdesignwerks
Maserati Vendor Classifieds
Sep 10, 2015 04:00 PM
MC36
Southeast
Sep 1, 2015 06:39 PM
