Pressure Washer, Anyone?
Hey guys,
I wanted to see if any of you used a pressure washer in washing your car.
I want to buy one, but I'm worried that it may strip my paint, etc.
Would you recommend using a pressure washer?
Thanks.
Thanks.
thanks!
Try and get one w/ no more than 2000 psi....hold your hand in front of the spray at the furthest end of the spray. Bring your hand back close to the beginning of the stream. When it begins to hurt your hand, you know that as close to the car's paint as you want to be
1. Pressure washers use less water than directly spraying with a hose. If you use a water deionizer, you will conserve your resin and save money.
2. Pressure washer wands vary in intesnity. If you use a fan or spiral spray, the pressure will NOT damage your paint, even if you accidentally get close.
3. Pressure washers allow you to use attachments like a cam foam sprayer, which greatly enhances foaming action of detergents.
I use an electric one with 1900 psi pressure. 3 things to know.
Great points by everyone. If you use any kind of water filter, pay attention to the GPM recommendations. When it comes to cleaning, high GPM is important. However, when it comes to using your pressure washer with a water filter, Id recommend keeping the GPM lower. I had a Honda pressure washer which was 2500 psi, 2.5 gpm. This is overkill for washing cars. Ill be switching to an electric one with about 1900psi and 1.5 gpm. This will allow my CR system to last longer due to the lower gpm.
Also, 2500psi will not strip automotive paint, so dont worry about that. The psi is significantly reduced just a couple feet from the nozzle.
Anyone else use the Snap-On pressure washer? I'm mostly concerned with durability. The $100 one I bought from Harbor Freight just pooped out on me this weekend after only a few months of use. Learning more and more you get what you pay for. But on the other hand, I'm not quite ready to dish out $7-800 for a 'nice' one
Any other suggestions?
Such as?
Northern Tool and Equipment have some nice electric pressure washers. The basic one starts around $450 iirc and move up to $800ish. The more you spend the better the pump. The better the pump, the longer it will last(typically).
There are electric units that are much nicer and cost much more. But if you're not wanting to spend a bunch they don't really matter.
This one is pretty damn ugly and looks bulky as all heck, but also looks like it's tough as nails.
http://www.northerntool.com/shop/too...0514_200350514
What other 'nicer' ones are you referring to?
Thanks for the recs.
This is pretty close to what I have.
http://www.unoclean.com/Cam-Spray-30...-3000-PSI.aspx
