Scratch removal in plastic
Old Mar 9, 2010 | 10:26 AM
djantlive's Avatar
I noticed some fairly deep scratches (1mm) in the plastic part of a lower bumper. It is not painted.
Is there a compound or wet sand method to remove the scratch in plastic? What grit would you try? Will I end up scuffing up the plastic too much? If so, I will just leave it alone. The plastic is made of ABS, flexible, unpainted.
Old Mar 9, 2010 | 11:23 AM
detailjohn's Avatar
detailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to behold
If you sand the plastic you will remove all the texture. It can be filled, retextured and trim painted, might be your best bet.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
SM_ATL
Mar 26, 2016 03:02 PM
jaehoppa
Oct 22, 2015 09:17 PM
sleepy
Sep 4, 2015 11:59 AM
