Water spot removal
Old Aug 1, 2010 | 11:00 AM
INSman's Avatar
INSman is a splendid one to beholdINSman is a splendid one to beholdINSman is a splendid one to beholdINSman is a splendid one to beholdINSman is a splendid one to beholdINSman is a splendid one to beholdINSman is a splendid one to behold
I use a very good product on my boat that works equally as well on cars and such called HOT SAUCE... Takes off water spots while also leaving a wax type finish behind. Not sure where you can get it in your local area, maybe do a Google search ?
Old Aug 1, 2010 | 11:51 AM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Originally Posted by MoeMistry
That is PPM reading. That's on the higher side which might explain why you go through a lot of resin. You probably already know this, but use your promo code here on 6speed when you order resin from us and pick up the r6-20. It's 1 cu/ft of resin. The dic-20 takes .33 cu/ft of resin. So the r6-20 will change the system 3 times. Another great feature of getting the bagged resin is how fresh it is. It's vacuum sealed.
I purchased my 3 DIC-20 refills from you a few months ago. On my second one right now. It is very convenient. Just wish I didn't go through it so quickly.
Old Aug 1, 2010 | 03:47 PM
bbywu's Avatar
Ed, do you buy resin by the drum? There's a fair amount of savings buying in bulk (ask me how I know )
Old Aug 1, 2010 | 03:58 PM
MoeMistry's Avatar
Premium Sponsor
Bob, next time get the r6-20...bagged version of the drum and with your 6speed discount, just as cheap.
Old Aug 1, 2010 | 03:59 PM
MoeMistry's Avatar
Premium Sponsor
OK..are you suing the CR with a pressure washer. If not, you should. It'll double or triple the life of the resin. Get an inexpensive one from costco or home depot.
Old Aug 1, 2010 | 04:33 PM
bonehead's Avatar
So the drum is the same as the 6 bulk bags?
Old Aug 1, 2010 | 06:33 PM
bonehead's Avatar
Just bought a bottle of the CG Water Spot Remover. Heard some good things about it. I just don't want to polish the paint again so soon. Hopefully will have some good results to report.
Old Aug 1, 2010 | 06:55 PM
Dan1's Avatar
Dan1 has a spectacular aura aboutDan1 has a spectacular aura aboutDan1 has a spectacular aura about
You can try vinegar.
Old Aug 1, 2010 | 07:00 PM
bonehead's Avatar
Tried it right after it happened. Didn't work. 50/50 IPA. Didn't work. Swearing expletives at it. Didn't work
Old Aug 2, 2010 | 03:39 PM
MoeMistry's Avatar
Premium Sponsor
yes. They're both 1 cu/ft
MoeMistry's Avatar
Premium Sponsor
LOL...let us know if the CG stuff works.
Old Aug 2, 2010 | 07:02 PM
bonehead's Avatar
Yes. I had a POS Harbor Freight electrical unit which lasted about 10 washes. I then ponied up and bought this
Noisy as heck, but built like a tank. CAT pump, 2.6 GPM, 3000 PSI. Used it to wash my car and my driveway. Bought a foam cannon attachment for $20 which is pure awesomeness
Old Aug 2, 2010 | 07:54 PM
fairway551's Avatar
fairway551 is infamous around these parts
Bonehead -- did you get the Green Earth Foam Blaster from Home Depot? If so, please provide details on how you are using it. What type of car wash are you using, what dilution, etc. Thanks.
Old Aug 2, 2010 | 08:02 PM
bonehead's Avatar
Spot on, fairway.
Best $20 I've spent in a LONG time.
I bought a jug of Meguiar's Gold Class for $12 at Costco. Pour it in undiluted. Stuff is cheap enough. It sucks it up pretty quickly. Think it took 3/4 of the reservoir filled with soap to get that pic I took.
Old Aug 3, 2010 | 06:04 PM
bbywu's Avatar
Ed, you've found car washing bliss!
