PO203 Power Finish
Old Sep 30, 2010 | 10:36 AM
mass's Avatar
mass is infamous around these parts
PO203 Power Finish
Anyone use this? I used to use SIP then 106FF, but this seems to be a good alternative to save some time. Even if the results are not as good as the 2 step process, if it is "good enough" it may be worth it.
Old Oct 2, 2010 | 09:10 PM
detailjohn's Avatar
detailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to behold
Power Finish is a great product, a great one step on lighter colored cars.
John
Old Oct 2, 2010 | 11:30 PM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
Menzerna Power Finish is a great one step polish.
As John mentioned its great on light colored cars.
If you need some more cut use a pad with more cut.
Need less use a pad with lesser cut.
Old Oct 3, 2010 | 09:16 AM
MoeMistry's Avatar
Premium Sponsor
We use this with a flex and a CCS White pad. Works like a charm on most cars. If you use it with a pc or flex, you can get away with it on darker cars. Just make sure to finish it down so the polish is almost transparent. If you're OCD, it doesn't quite do what SIP and Super Finish can. However, for a one-step, it's an excellent polish. Then follow it up with you favorite wax.
Here's a great kit:
http://www.glisteningperfectionstore...ish-Kit/Detail
Peach PTT
Oct 5, 2015 10:54 AM
Michael_s
Sep 11, 2015 08:03 PM
Ferrari
Aug 24, 2015 04:35 PM
