Yellow Seatbelts, how to clean them
Old Nov 18, 2010 | 02:10 PM
simtiaz's Avatar
simtiaz has a spectacular aura aboutsimtiaz has a spectacular aura about
Any suggestion on how to clean yellow seatbelts? it's getting little dirty from normal use. Thanks in advance
Old Nov 18, 2010 | 10:27 PM
detailjohn's Avatar
detailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to behold
This is not an easy thing to clean. I like to run a good cleaner like Auto Glym Interior Shampoo through a tornador high pressure cleaning gun, or you can remove the seatbelts and let them soak in a detergent overnight. If they're not too expensive, unfortunately they will never look as good as they would if replaced. Seatbelts are truly one of the most difficult things to clean on a car.
John
Old Nov 19, 2010 | 12:04 AM
RPGilberts87's Avatar
RPGilberts87 is infamous around these parts
+1 on that one john!
Old Nov 19, 2010 | 04:19 AM
TOGWT's Avatar
TOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to behold
Seatbelts:
For spot stains use a fabric cleaner (303 Cleaner & Spot Remover™)
1. Pull the belts from the retractor and gently close the door on the belt, clean and allow to air dry before opening the door and retracting the belt. Do not use bleach, strong detergents, or dye on the seat belts as this may severely weaken them and render them ineffective in a crash.
2. Once fabric is dry apply a fabric protection (303™ High Tech Fabric Guard)
3. While you are cleaning the belts, take the opportunity to closely inspect them for damage and security of attachment, ensure here are no cuts, tears or abrasions (you should always inspect for damage etc if they get caught by a closing door)
4. After a while the seat belt mechanism becomes slow and / or will not retract when released. This can be avoided by cleaning the upper anchor; as the seatbelt retracts it leaves behind a film of dirt, which builds up over time. Use compressed air to remove dust and then using a Q- tip and some Isopropyl alcohol (IPA) you can clean the seat belt anchor / retracting mechanism. Once clean add some Plexus Plastic Cleaner to provide lubrication.
Maintenance - clean seat belts with a 5:1 P21S® High Performance Total Auto Wash / distilled water solution, ensure they are thoroughly dried before use
Alternative products –C-28 Seat Belt Cleaner and Spot Remover from PRO® is a non-flammable and non hazardous concentrated cleaner that safely removes dirt, oil, grease and stains from seat belts
Old Nov 19, 2010 | 11:32 AM
simtiaz's Avatar
Thanks for your suggestions guys much appreciated.
Sid
Old Nov 19, 2010 | 03:56 PM
MoeMistry's Avatar
Premium Sponsor
Originally Posted by TOGWT
Seatbelts:
Never thought to use the P21S TAW...will give it a try.
Old Nov 19, 2010 | 06:43 PM
Duff0000's Avatar
Duff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond repute
Ive had great luck with a steam cleaner.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Rguy
Apr 12, 2020 11:11 PM
pjb84
Sep 2, 2015 12:57 AM
