waxing right after IPA , skipping cleaner fluid.. is it advisable?
I never really understands the logic behind cleaner fluid / HD cleanse..
Isn't the paint as clean as it is after IPA wipedown after polishing ? How would another type of oil help the wax which has oil in it bond better?
Marketing gimmick?
Marketing gimmick?
Both IPA and HD cleanse contain chemical cleaners, HD Cleanse also contains light abrasives that help to clean the paint and provide a 'key' for the wax to anchor to
The idea behind using IPA after polishing / compounding is to ensure that there is nothing 'filling' ( i.e. wax, oils, Kaolin, etc) the scratches, and they are actually removed not disguised
Using paint cleansers after polishing is more than just cleaning the paint. As Jon mentioned, it's basically the missing link between bonding a carnauba to a synthetic polished paint. We've tried both with and without paint cleanser after polishing. When using a carnauba, you'll get better application, a warmer look, and longer protection if you apply a paint cleanser prior to waxing.
TOGWT
Detailing
Sep 29, 2015 07:05 AM
