Any special recomendations when using well water?
Old May 1, 2012 | 03:05 PM
GT3Racerich's Avatar
GT3Racerich is infamous around these parts
Question Any special recomendations when using well water?
We are in the planning stage of building a new house and the property will have well water. I have never had that before and was wondering if anything needs to be done to the water or is it safe for washing the cars. I would like to have it set up ( the garage) when new rather then start changing things. Thanks in advance, any advice is appreciated.
Rich
Old May 1, 2012 | 08:22 PM
fairway551's Avatar
fairway551 is infamous around these parts
Have the hardness of the water tested. If it's hard (and I'd bet a lot of money that it's VERY hard), you need a whole house water softener. Otherwise, you will have major spotting problems. Once you have the softener, buy a CR Spotless to produce deionized water. The resin will last a lot longer if you feed it softened water and you'll never have to dry your car after washing.
Old May 6, 2012 | 06:28 PM
bbywu's Avatar
Use a TDS meter to determine hardness. Hard water always spots. Even softened water will spot. Fairway551 is correct - use a water deionizer and save yourself hours of work buffing out water spots.
PelicanParts.com
Panamera Vendor Classifieds
Sep 11, 2015 12:13 PM
PelicanParts.com
Sep 11, 2015 12:11 PM
PelicanParts.com
996 Vendor Classifieds
Sep 11, 2015 12:08 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Sep 11, 2015 12:06 PM
PelicanParts.com
997 Vendor Classifieds
