How do you detail your engine?
Old Feb 19, 2007 | 11:07 PM
tdekany's Avatar
tdekany is infamous around these parts
I steam clean when doing engines but sometimes I pressure wash as well. Depending on the car.
Steam clean and protected with FK1's #108.
Old Feb 20, 2007 | 02:31 PM
Bill in Atlanta's Avatar
Bill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud ofBill in Atlanta has much to be proud of
Oak,
What did you use to remove the Cosmoline ?
thanks,
Bill
Old Feb 21, 2007 | 11:50 PM
Secure's Avatar
Secure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud ofSecure has much to be proud of
My way:
First get some engine degreaser. I always used some Engine-Brite in a can. Foam works best. It’s thicker and really does some cleaning.
Next hit the engine with a hard jet of water on the more greasy areas of the engine. Just be aware of wires, connectors, etc where water can sit and give electrical issues. Might be best to get some aluminum foil and wrap these connectors and wires with.
Next let the engine run for about 5 mins or use a leaf blower to dry the engine best you can.
Next get some Armorall low gloss formula and do a 70/30 mix with water. Shake up really well.
Now coat the full engine. And start the engine and let it run – idle for 5 mins.
Next after 5-mins turn the motor off, and wipe the engine fully with a rag.
Next re-coat the engine with the armorall solution.
Start the engine up and let it run for another 5 mins
Turn off the engine and re-wipe really good.
That’s it…the motor should look like brand new. In time the solution will burn off the headers etc, so expect some slight smoke when you start up the car.
Old Mar 25, 2007 | 11:13 PM
John Romano's Avatar
John Romano is infamous around these parts
Originally Posted by MoeMistry
Cover the air box with foil. Run the engine for about 5 minutes, before putting foil on. Spray the engine bay with a natural cleaning agent, I use Zymol Strik. Let the product sit for about 5 minutes. Rinse. If it's really dirty, spray down engine again after rinse and soak, use a soft brush to aggitate things, then rinse again. Wipe dry using a microfiber towel.
in a 996, that's all I have to worry about covering is the intake? I can just blast away inside the engine compartment with a hose?
Old Mar 26, 2007 | 01:23 PM
MoeMistry's Avatar
Premium Sponsor
Run the engine a bit, cover the intake, use as little water as you need to clean. You don't want to blast water in there but you should be able to clean it well.
Old Mar 26, 2007 | 03:44 PM
Cool. Thaks. and what's okay to spray on everything afterward to make the hoses and plastic stuff look all clean and rich without attracing dust?
Thanks!!
Old Mar 27, 2007 | 12:30 AM
cpu77's Avatar
cpu77 is infamous around these parts
Originally Posted by oak
top side is a breeze, its the bottom of the engine that takes some toll. small dental mirrors and prophy picks and alot of elbow grease.
WOW! You have inspired me to clean my mess up! Really looks great. Did you polish parts on the car?
Old Mar 27, 2007 | 01:18 AM
oak's Avatar
oak
yeah, it's amazing what a little mothers polish goes along way.
Old Mar 27, 2007 | 12:38 PM
You have to admit, the underside of that car is a work of art! How long did it take you?
Old Mar 27, 2007 | 02:37 PM
oak's Avatar
oak
not too long, maybe a couple summers.
Old Mar 27, 2007 | 02:51 PM
vincentdds's Avatar
vincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond reputevincentdds has a reputation beyond repute
Oak
You're mad man. I 'll start on mine this summer and hopefully be done before 2010.
Old Mar 31, 2007 | 06:54 PM
BlackS4Terror's Avatar
BlackS4Terror is infamous around these parts
One suggestion: replace that expansion tank. Looks much better.
Originally Posted by pyiu
I use P21S Autowash for my customers, of course like Moe said use a brush if you can get everything the first time. Then I follow with Adam's VRT (dressing) and Adam's In and out (for the hard to reach areas)
Check out some engine shots.
Sep 10, 2015 03:20 PM
The Oss
Aug 24, 2015 08:19 PM
Gewgaw
Aug 19, 2015 11:52 PM
