Originally Posted by Hogapalooza
(Post 2731785)
You don't find them standing on the street corner w/ a pimp, you have to go through a Madam.
The hose needs to be a good length, kink resistant, and long. This is the one that I have used for forever with my Rigid Vacuum.
http://www.homedepot.com/Tools-Hardw...atalogId=10053 Without busting out the math equations, suction is amplified if you reduce the available suction area. Using the crevice tool for everything increases the amount of suction that you are getting, so I use this tool for absolutely everything. It is the only end that you are going to need. Team that up with a detail brush of some type and use that to tackle your whole interior. The Vacuum isn't just good for cleaning carpets, and seats, you should use it for everything. Without toughing the surface, use the brush to remove dirt and dust from crevices and seams on doors, around windows, switches, vents, cupholders... literally everything. Moe and I probably spend more time Vacuuming an interior than we do anything else, it is hands down the most important step as it really sets the tone for the rest of the interior cleaning process. So get a good brush, and a good vacuum, and really take your time and make the most out of your vacuum. |
Originally Posted by GlisteningTech
(Post 2733312)
http://www.homedepot.com/Tools-Hardw...atalogId=10053 Without busting out the math equations, suction is amplified if you reduce the available suction area. Using the crevice tool for everything increases the amount of suction that you are getting, so I use this tool for absolutely everything. It is the only end that you are going to need. Team that up with a detail brush of some type and use that to tackle your whole interior. The Vacuum isn't just good for cleaning carpets, and seats, you should use it for everything. Without toughing the surface, use the brush to remove dirt and dust from crevices and seams on doors, around windows, switches, vents, cupholders... literally everything. Moe and I probably spend more time Vacuuming an interior than we do anything else, it is hands down the most important step as it really sets the tone for the rest of the interior cleaning process. So get a good brush, and a good vacuum, and really take your time and make the most out of your vacuum. What do you think about this kit? http://www.homedepot.com/webapp/wcs/...3+90401+524502 |
That kit isn't bad, it definitely has everything that you are going to need.
If you don't want to get all of those other attachments for other possible uses, the crevice tool is literally the only attachment that we ever use. It literally never comes off the hose. So the rest is up to you, but the crevice tool is the only one that I think is totally necessary. |
I use the metrovac "vac n blow" similar to the one which started this thread. I use a smaller model of the same blower. The one I use is four horsepower and is more compact and also mounts to the wall in my garage. This machine really works. It has great attachments which can get into all the little crevices in the car. They sell a few different models through amazon. I have been very pleased with unit. Worth a serious look.
+1 on the Metro Vac n Blo. Cheesy name, but great vacuum. The large one (which I have) mounts on the wall and has a 24 foot hose. Great suction, reasonable quiet and very convenient to have it on the wall with a long hose. Can be seen here:
http://www.autogeek.net/walmounvacnb.html |
Well, I bought a 12gal Ridgid vac today. Took it out of the box only to realize it is just way too big for my needs. I think even the smaller units would be too unwieldy.
What are everyone's recs for a good hand-held unit? |
Originally Posted by bonehead
(Post 2791761)
Weird, I just bought the $37 rigid orange hose today and some attachments just for my car. I didn't want to use my regular shop vac hose in the car, its filthy.
Originally Posted by MoeMistry
(Post 2791959)
We'll be getting a new unit for 2010 from Double K that is both a blower and a vacuum. It's not that big so it'll be perfect for your garage. I'll keep you posted. It should be a week or two away.
(Post 2791997)
Estimated price??
(Post 2792024)
Sub $200---current model, no longer available as it phased out for the new one, retailed for $229 and we sold it for $189. We'll probably do a group buy if enough interest is there.
(Post 2792025)
Is this a handheld unit or a standing vac?
http://www.glisteningperfectionstore...fa997c48_l.jpg Here's a link to the current model: http://www.glisteningperfectionstore...dsh-Vac/Detail |
I bought a small 5 gallon Shop Vac from Lowes that's 5.5 hp and works flawlessly for my personal and mobile detailing needs. My main concern was having enough suction and 5.5 hp is on the relative high side.
Metro vac makes a smaller hand-held model I have seen advertised. I have not used it myself but my buddy has it and says it's great. Tells me it's much more powerful than the usual hand-helds. I still like the unit where it just sits on the floor or garage wall and long tubing it comes with really has serious suction. Will be much easier to handle as compared to the shop vac you purchased.
