Can I use this to polish?
Old May 26, 2007 | 01:12 AM
TheDon's Avatar
TheDon is infamous around these partsTheDon is infamous around these partsTheDon is infamous around these partsTheDon is infamous around these partsTheDon is infamous around these parts
Old May 26, 2007 | 06:39 AM
MoeMistry's Avatar
Premium Sponsor
I'd say no. For starters, it's not designed for automotive application. Second, I don't think you can find a pad to use that will have the polisher's shape. Tird, I've used that polisher to sand molding; it merely vibrates quickly. Good for sanding, not polishing a car. Your best bet it the porter cable 7424 polisher or a cyclo.
Old May 26, 2007 | 09:25 AM
TheDon's Avatar
Ok thanks. I had it laying around so I just wanted to check. Im thinking of getting the PC7424. What other accessories would i need to get with it to get started? Im trying not to spend too much $$. I want to be able to get swirls out and make my cars shiny. For personal use only. Thanks.
Old May 26, 2007 | 09:56 AM
MoeMistry's Avatar
Premium Sponsor
If $$ is an issue, save up. You'll thank yourself. Don't waste your money on a cheap polisher, pads, and polish. The PC 7424 should be around $150, you'll need some Lake Country pads, usually around $15 or less each, and some Menzerna polishes. Depending on type and size, look to spend about $30-50 a bottle. It all depends on how bad the swirls are. If it's too deep, you'll need to have them professionally removed with a high-speed. But the PC and the products I mentioned should make a huge dent in bringing the paint back to life. PM me for more info.
Old May 26, 2007 | 11:12 AM
2thfixr's Avatar
2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold
+1 on the Menzerna. I would recommend starting with Menzerna Final Polish II with the black Lake Country Pad. If you have a lot of swirls, then you might want to start with Menzerna PO106FF before the FPII because it's formulated for Mercedes Ceramcoat. Follow it up with Pinnacle Soverign and a distilled water buff. Like Moe said though, if the scratches are too deep, you will need a pro to use a regular orbital instead of a DA polisher like the Porter Cable.
Old May 26, 2007 | 03:35 PM
TheDon's Avatar
So I will proboby get this polisher because I have a 50 dollar amazon gift card.
http://www.amazon.com/Porter-Cable-7...0072764&sr=8-1
What else do I need with it? And can i buy the rest localy? I havent found a single local store that carries polishers etc. I checked home depot, lowes, autozone, and pep boys.
TOGWT
Detailing
Oct 1, 2015 07:59 AM
