Novitec 599 GTB Parts Available
Old Nov 19, 2007 | 03:27 PM
ExoticaPorsche's Avatar
ExoticaPorsche is infamous around these parts
Novitec has just released their products for the 599 GTB. Prices are to be made public next week. PM me for pricing.
Old Nov 19, 2007 | 03:28 PM
1. Drivetrain
- Novitec Power Stage 2
Consisting of a new adjusted engine electronic with modified group of curves and higher cutoff speed to 8,550 RPM (thereby higher end speed). In addition a stainless steel exhaust system in combination with 70mm stainless steel replacing pipe.
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1072
- Novitec Power Optimized ECU's
Higher performance through new adjusted engine electronic with modified group of curves as well as higher cutoff speed to 8,550 RPM (thereby higher end speed)
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1073
2. Exterior
- Front Bumper Spoiler
Add-on to original bumper, supports the negative lift
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=438
3. Brakes
- Steel Flex Brake Line Kit
Includes 4 lines to fit OE system
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1083
- High Performance Brake System
Two 8-piston brake calipers and 380mm discs in the front and two 4-piston brake calipers and 380mm discs in the rear; 2 brake cooling ducts, steel flex brake lines, brake pads. Red, silver, black or customer requested colors.
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1082
4. Lighting
- Black Side Marker Kit
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1076
5. Exterior
- Side Skirt Panels
Add-on to factory side skirts
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1078
6. Tires and Wheels
- 3-pc Wheels
Silver 21x9” & 21x12.5”
Black 21x9” & 21x12.5”
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1081
Old Nov 19, 2007 | 03:30 PM
Rear ad.
Old Nov 19, 2007 | 03:31 PM
7. Exterior
- Rear Wing
Supersport wing, wind tunnel tested.
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1080
8. Lighting
- Black Taillights
Shines red when on
- Black LED Third Brake Light
Shines red when on
- Black Reflectors
9. Exhaust
- Power Optimized Exhaust System
Stainless steel with 2 90mm tips (2 left & 2 right) with or without valves
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1074
- Stainless Replacing Pipe
Stainless steel replacing pipe starting from the manifolds (2 pieces)
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1075
10. Exterior
- Rear Diffuser
Add-on, wind tunnel tested, supports negative lift
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1079
11. Suspension
- KW Coilover Supension Kit
Includes dual adjustable stainless steel shock absorbers with separated expansion reservoir at damper housing, compression and rebound adjustable in front and rear as well as CAN control unit.
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1084
- Aluminum Spacers
Made of high strength aluminum, corrosion protected by anodize, set of 2 pieces including mounting material.
10mm, Widens track 20mm
15mm, Widens track 30mm
20mm, Widens track 40mm
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1085
Old Nov 19, 2007 | 04:21 PM
Use our new Real Time Chat feature on our website. If there is any questions you have about prices, parts or need better pics, just click on the chat feature and we will talk to you in real time.
WheelB
Lamborghini
Aug 29, 2015 11:06 AM
Mar48
Aug 24, 2015 01:13 PM
