599 Novitec Parts Prices have Dropped!
Novitec called to let us know that they have lowered all their prices significantly! All the 599 prices are the lowest they ever have been. I don't know how long this will last, so get them now!
1. Drivetrain
- Novitec Power Stage 2
Consisting of a new adjusted engine electronic with modified group of curves and higher cutoff speed to 8,550 RPM (thereby higher end speed). In addition a stainless steel exhaust system in combination with 70mm stainless steel replacing pipe. $14,999
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1072
- Novitec Power Optimized ECU's
Higher performance through new adjusted engine electronic with modified group of curves as well as higher cutoff speed to 8,550 RPM (thereby higher end speed) $5,999
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1073
2. Exterior
- Front Bumper Spoiler
Add-on to original bumper, supports the negative lift $2,259, Carbon $4,859
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=438
3. Brakes
- Steel Flex Brake Line Kit
Includes 4 lines to fit OE system $599
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1083
- High Performance Brake System
Two 8-piston brake calipers and 380mm discs in the front and two 4-piston brake calipers and 380mm discs in the rear; 2 brake cooling ducts, steel flex brake lines, brake pads. Red, silver, black or customer requested colors. $15,999
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1082
4. Lighting
- Black Side Marker Kit
$199
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1076
5. Exterior
- Side Skirt Panels
Add-on to factory side skirts $1,499, Carbon $3,459
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1078
6. Tires and Wheels
- 3-pc Wheels
Silver 21x9” & 21x12.5” $9,996
Black 21x9” & 21x12.5” $11,196
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1081
7. Exterior
- Rear Wing
Supersport wing, wind tunnel tested. $2,799, Carbon $4,899
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1080
8. Lighting
- Black Taillights
Shines red when on $3,199
- Black LED Third Brake Light
Shines red when on $699
- Black Reflectors
$699
9. Exhaust
- Power Optimized Exhaust System
Stainless steel with 2 90mm tips (2 left & 2 right) without valves $5,399, with valves $7,199.
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1074
- Stainless Replacing Pipe
Stainless steel replacing pipe starting from the manifolds (2 pieces) $3,599
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1075
10. Exterior
- Rear Diffuser
Add-on, wind tunnel tested, supports negative lift $1,999, carbon $4,459
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1079
11. Suspension
- KW Coilover Supension Kit
Includes dual adjustable stainless steel shock absorbers with separated expansion reservoir at damper housing, compression and rebound adjustable in front and rear as well as CAN control unit. $8,399
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1084
- KW Coilover Supension Kit – Hydraulically Adjustable
(dual adjustment) hydraulically adjustable in height including dual adjustable stainless steel shock absorbers with separated expansion reservoir at damper housing, compression and rebound adjustable in front and rear as well as a CAN control unit and 40mm hydraulic adjustment at the front axle. $11,999
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1167
- Aluminum Spacers
Made of high strength aluminum, corrosion protected by anodize, set of 2 pieces including mounting material.
10mm, Widens track 20mm $399
15mm, Widens track 30mm $459
20mm, Widens track 40mm $499
http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1085
2. Exterior
3. Brakes
4. Lighting
$199
5. Exterior
- Side Skirt Panels
6. Tires and Wheels
- 3-pc Wheels
7. Exterior
- Rear Wing
8. Lighting
- Black Taillights
- Black Reflectors
$699
9. Exhaust
10. Exterior
- Rear Diffuser
11. Suspension
- Aluminum Spacers
Chris Green@USP
997 Turbo Vendor Classifieds
Jan 28, 2016 02:22 PM
Chris Green@USP
996 Turbo Vendor Classifieds
Aug 20, 2015 11:30 AM
