Notices
Garage Forum Share pictures of your garage with the rest of the 6speedonline members. Learn about Garage flooring, painting, art, and more in this forum.
Installing a 2 post lift some cement questions
Old Sep 5, 2012 | 10:07 AM
underpressure02's Avatar
underpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond reputeunderpressure02 has a reputation beyond repute
I am building my garage finally and in the one bay I am planning on putting a 2 post lift and want to see how everyone else installed theirs.
My plan for the lift is to dig out a footer the width of the lift left to right and build a rebar cage then have it filled with cement. The rest of the garage floor would consist of 6inch thick concrete. I am just wondering if that is overkill or is a good idea to prevent cracking or other problems. The heaviest thing I plan on lifting is my Chevy K3500 dully. Some people I have talked to say that will be more then enough some say its overkill. I just don’t want to crack the floor or have issues. Any thoughts or help would be great.
Old Sep 14, 2012 | 08:30 PM
vrybad's Avatar
vrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant future
Definitely go as thick as reasonably possible.
I cut my floor for my 2-post, and went about 8 inches deep under each post, with about 1 foot or more width at a minimum to the side of each post, and went 6 inches deep between posts.
I also did the rebar cage, as you are planning, but since I cut an existing floor, I also drilled rebar dowels horizontally into the existing concrete to tie both the old and new floors together.
Worked very well and no issues so far, nor do I anticipate any.
Actually, I feel sorry for anyone that may attempt to remove that portion of the floor!!
MadWhip
Sep 3, 2015 02:04 PM
gulf gt
Aug 27, 2015 10:27 AM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
Aug 21, 2015 09:56 AM
ppwchiang
Aug 20, 2015 10:28 AM
