Notices
Garage Forum Share pictures of your garage with the rest of the 6speedonline members. Learn about Garage flooring, painting, art, and more in this forum.
Garage remodel - the redo
Old Nov 26, 2012 | 07:54 PM
Sharp's Avatar
Sharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud of
looks amazing!! is that a concrete finish or is that a tile? I too am looking for a good durable flooring solution.
Old Nov 26, 2012 | 08:59 PM
bbywu's Avatar
Originally Posted by HIRISC
Nice upgrade.
Thanks!
It's concrete - a technique called Granicrete. If you Google it, you'll get more info. It needs to be sealed about 3-5 years. But I've already spilled some oil, and it wiped right up.
Old Nov 26, 2012 | 09:49 PM
slavik's Avatar
slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !slavik Is a GOD !
Awesome upgrade! Love the simplicity of it.
Old Dec 14, 2012 | 03:50 PM
bbywu's Avatar
Added artwork:
Old Dec 14, 2012 | 03:52 PM
bbywu's Avatar
...and a 917.
Old Dec 14, 2012 | 04:00 PM
GothamCayenne's Avatar
GothamCayenne is infamous around these partsGothamCayenne is infamous around these parts
really amazing before and after!
Old Jan 7, 2013 | 05:58 PM
willybeen's Avatar
willybeen is infamous around these parts
I cant get over the before pictures. The cabinets are amazing. (I'm glad I stumbled onto the garage section today.
Old Mar 24, 2013 | 11:34 PM
AP328's Avatar
AP328 is a splendid one to beholdAP328 is a splendid one to beholdAP328 is a splendid one to beholdAP328 is a splendid one to beholdAP328 is a splendid one to beholdAP328 is a splendid one to behold
The garage looks great! We are just finishing ours, hope to have it done by the end of the summer (a multi-year project). What heater did you use? I am in Alberta and we see similar extremes of weather and I don't want the garage heated other than occasionally.
Old Mar 29, 2013 | 01:28 PM
YNOT2K's Avatar
YNOT2K is infamous around these parts
Great looking garage!
Old Apr 5, 2013 | 04:55 PM
bbywu's Avatar
I bought a Cadet CGH562 5,600 Watt portable garage heater from Home Depot. It plugs in to a 240/208 V, I had 30A wiring into my garage cabinets. All I do is open the cabinet, and turn it on. During the summer, it is hidden.
I chose this electrical fan heater rather than a gas heater because it is hidden. Gas heaters will have to be mounted in the ceiling or such, and for a small garage, is bulky. This Cadet is hidden out of view.
My garage is insulated - it never fell below 40F when the outdoor temps were -5 to -10F. When I turned it on, the garage could rise to 70F very quickly.
Old Apr 5, 2013 | 08:14 PM
mattgarrett's Avatar
mattgarrett is a jewel in the roughmattgarrett is a jewel in the roughmattgarrett is a jewel in the roughmattgarrett is a jewel in the rough
bbywu,
Garage looks great. Congrats!
Old Apr 6, 2013 | 12:16 AM
AP328's Avatar
Thanks for letting me know about the heater - it gives me ideas. We are only looking to extend the season a bit, so that should help.
Old Apr 16, 2013 | 07:10 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Very nice
Old Apr 24, 2015 | 07:39 PM
BobbySpeed's Avatar
BobbySpeed is infamous around these partsBobbySpeed is infamous around these parts
Sweet!
Old May 2, 2015 | 07:44 AM
See U n Rear View's Avatar
See U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really niceSee U n Rear View is just really nice
Thumbs up may I play in your sand box?
You really planned well and everything is professionally done. All the way down to the Hidden cadet and 30 amp.
I will be soon creating and designing an ultimate space for my vehicles, otherwise know as, "the garage," and I have gotten many tips from your Remodel.
If you may, the things I like are the recessed can lights. Curious if your lighting contractor use a lighting intensity meter to determine if the garage was uniformly lit? Although I like the recessed lights, I would like to either remove the diffusers covering the florescent lights or simply have directional canned lighting in area's where I would be waxing any vehicles. You see, it might sound silly, but I have a personal issue with diffusers...
Also, very nice using the Granicrete. I will research that. One of my dealers has a hard rubbery surface whereby the tires squeak when turning on them and it appears that there is no discernible peeling. I need to find out what that material is.
It is wise that you have lifted the cabinets off the ground to avoid moisture intrusion into the cabinets. I need to think about this...
Is that long 3" or so metal looking bar that extends from one side of the front are of the garage floor to the other a drainage area or a wheel depression?
Lastly, some things I would like to change. More for me to remember for my garage and not to critique yours.
I would like for there to be no cabinets above the work area. Just a useable wall for tools. The wood block is great surface to work on.
I would need one switch that controlled the entire garage lighting system, as well as Bank switches that controlled certain area's. and remote controlled fans, because I live in California.
I would have the cabinet that opened without hardware, due to the fact that I'm often moving at full speed, and would tear a number of pockets and shirts by having any one of them catch on me. If you ever done it you know what I mean.
I like how you utilized separate breakers, the parts bin, flooring, double pane windows, and locally built cabinets.
You have really made this garage, a truly desirable space to view and to enjoy. It is impressive what you have accomplished. You pulled out all the stops and have a beautiful work of art to show for it. Thank you for allowing me to, "paint my garage," in my minds eye.
