Group Buys This forum is for special group purchases offered by our 6speedonline sponsors. Join in on a group buy purchase, and save big!
Vivid Racing - 996/997 VF Engineering Supercharger GROUP BUY
Old Nov 9, 2012 | 06:14 PM
vividracing2's Avatar
Site Sponsor
vividracing2 has a reputation beyond reputevividracing2 has a reputation beyond reputevividracing2 has a reputation beyond reputevividracing2 has a reputation beyond reputevividracing2 has a reputation beyond reputevividracing2 has a reputation beyond reputevividracing2 has a reputation beyond reputevividracing2 has a reputation beyond reputevividracing2 has a reputation beyond reputevividracing2 has a reputation beyond reputevividracing2 has a reputation beyond repute
Arrow Vivid Racing - 996/997 VF Engineering Supercharger GROUP BUY
This group buy will be running for both the 996 and 997 Carrera crowd so the overall discount will be combined with purchases for both models!
Having used all forced induction systems on the market for the Porsche 911 Carrera, including our own designed turbo kit, the VF Engineering supercharger system is hands does the best upgrade you can get. If you are starting your mod process, continue reading. If you have already added mods, the only thing you need to retain is your Exhaust System. So, what are the first things people tell you to buy? Exhaust, Headers, Intake, ECU Flash. Right there that is spending just over $4000. Add in a plenum and you have just spent about $5000 without installation. Here is the thing... The VF Engineering supercharger adds in a true 150HP gain realized on a stock 997 Carrera. All those mods are not cumulative.
So what do you get from VF Engineering for your 911 Carrera?
  • ECU Tuning
  • Upgraded Injectors
  • Vortech V3 Centrifugal Supercharger with self contained oil
  • Porsche OEM GT3 Front Radiator for air to water intercooler
  • Supercharger CNC Machined Bracket
  • Roto Molded Black Plastic Intake Tube
  • All required hardware - You need NOTHING Else
  • 6psi of boost taking you to an 11sec 1/4 mile
We have 2 different kit offerings for the 997 crowd:
Porsche 997 911
2005-2008 Carrera(non S)
325 hp / 273 ft/lbs Stock
VF475
480 hp / 370 ft/lbs
6.0 PSI
V3 supercharger
ECU software flash
Porsche 997 911
2005-2008 Carrera S
355 hp / 295 ft/lbs Stock
VF510
510 hp / 380 ft/lbs
6.0 PSI
V3 supercharger
ECU software flash
We have 2 different kit offerings for the 996 crowd:
Porsche 996 911
1999-2001
296 hp / 258 ft/lbs Stock
VF425
425 hp / 360 ft/lbs
6.0 PSI
V3 supercharger
ECU software flash
Porsche 996 911
2002-2005
320 hp / 273 ft/lbs Stock
VF470 $7900
470 hp / 360 ft/lbs
6.0 PSI
V3 supercharger
ECU software flash
Now on to the good stuff!!!!!
Group buy will be running until December 31st, 2012
To enter into the group by a $4,000 deposit will be required to reserve your spot. This deposit is non refundable and will put your unit into production right away.
The discount structure is as follows for 997's:
1-4 kits sold
Save $1,000
5-9 kits sold
Save $1,200
10+ Kits sold
Save $1,400
Retail pricing on either of the 997 kits is $8,900
The discount structure is as follows for 996's:
1-4 kits sold
Save $800
5-9 kits sold
Save $1000
10+ Kits sold
Save $1,200
Retail pricing on either of the 996 kits is $7,900
Any questions or to become a member of the group by please contact me directly at:
480.966.3040
Ext. 230
josh@vividracing.com
http://www.youtube.com/watch?feature...&v=tRy36cp-KZo
Details on the hardware:
The VF-Engineering designers set about designing the billet supercharger mounting bracket with CAD software creating solid models of parts to be CNC manufactured. The bracket was designed to utilize OEM bolt patterns and requires no alteration or relocation of any engine parts to be fitted. Made from 6061-Tx aircraft grade aluminum the bracket mounts to factory machined surface points on the aluminum engine block for a precision fit.
A V3 model Vortech Engineering supercharger unit was chosen after consultation with Vortech engineers and matching the engine’s volumetric efficiency with supercharger compressor maps. The V3 unit contains helical-cut gears for super quite performance – virtually silent with the engine compartment lid closed. The V3 supercharger has a 20psi and 1000cfm maximum capacity and is an over-engineered part for this Porsche application which is geared to produce a conservative 6psi in the engine’s intake manifold.
The fastidious design of the supercharger bracket, positions the belt driven supercharger to maintain use of the OEM spring loaded belt tensioner. The serpentine belt routing was designed to maintain the correct rotation of all the accessories and maintain optimal pulley wrap for maximum friction.
The Vortech air to water intercooler (charge cooler) was integrated into the tight fit engine bay as means of reducing charged induction (boost) temperatures. Lower charge temperatures promote engine safety by reducing knock and improving the quality of the combustion cycle. Air charge (boost) from the supercharger is directed through the chargecooler core before entering the throttle body. The cooler core contains isolated channels circulating with water from a separate self contained system cooled by its own radiator. VF-Engineering integrated a Porsche OEM front radiator and front bumper vents into the kit. Water is circulated by means of an added OEM Bosch water pump through OEM Good Year water lines. Intake air temperatures in the manifold were measured to be approx 140 deg F even with ‘spirited’ driving at 118 deg F ambient temperatures in Arizona desert conditions mid-Summer. This dramatic drop in charge temperature helps the 997 create consistent power. For added safety the chargecooler is designed to perform continuously whilst the ignition is on.
With all major components in place, the head of R&D at VF-Engineering set about shaping the air ducts from the filter to the throttle body. The intake pipe is specially tuned for its air flow characteristics and pressure relief system. Production pipes are manufactured from a lightweight molded high temperature polymer. The thermal insulating properties of the plastic pipes prevent heat transfer into the cooled charged air traveling inside them.
Engine management software was by written by VF with extensive testing performed on independent test cars. Multiple factors such as charge air temperatures, ignition timing, fuel trims, maps and injector performance were taken into account. The Carrera 2 and 4 test vehicles were extensively dynoed on the VF 4WD Mustang and monitored for wide band air fuel ratios at load levels often greater than would be experienced on the road. The results are an increase of 120 horsepower and 80 ft.lbs of fully useable torque.
This product is not compliant with the California Air Resourse Board and not for use on public roads in California. This applies to any aftermarket product that does not display a CARB EO#.
Old Nov 16, 2012 | 04:49 PM
Site Sponsor
keep the inquirys coming guys
Old Nov 23, 2012 | 07:30 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
cuious as to how many have been sold for the 3.8 997?
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
turbotuner20v
Sep 11, 2015 12:02 PM
