GT3/GT2/GT Vendor Classifieds
ModBargains.com | Forgestar F14 Wheels l Flow Form Technolgy l Ultra Light Weight !!!
Old Jul 2, 2010 | 02:51 PM
ModBargains.com's Avatar
ModBargains.com has a brilliant futureModBargains.com has a brilliant futureModBargains.com has a brilliant futureModBargains.com has a brilliant futureModBargains.com has a brilliant futureModBargains.com has a brilliant futureModBargains.com has a brilliant futureModBargains.com has a brilliant futureModBargains.com has a brilliant futureModBargains.com has a brilliant futureModBargains.com has a brilliant future
ModBargains.com is happy to introduce a brand new wheel from Forgestar: The Brand-new Forgestar F14.
This brand new lineup utilizes a combination of the best methods of forging and casting methods both in the same wheel. This is called Flow Form Casting, and is used by companies such as BBS and Enkei. These wheels are made to order and can be made to fit your Audi with a large range of offsets.
Flow Form Casting is a production procedure that turns the wheel (or rim section) over a special mandrel and three hydraulic rollers using tremendous pressure. The pressure and turning then force the rim area to form against the mandrel, creating the shape and width of the rim. During Flow Forming, the rim actually "flows" down to create the full rim width. During Flow Forming, pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel.
Oh yeah one more thing CUSTOM sizing and offsets guys! Forgestar wheels are available in a 18", 19", and 20" allowing you to decide exactly what diameter and width you want to run on your vehicle, rather being forced to run a set staggered size with cast wheels. Forgestar wheels can be made in virtually any offset, whereas standard cast wheels come in a set offset. This allows you to dial in exactly how you want your wheels to sit. Having custom offsets allows for fitment of wider wheels in stock suspension and lowered vehicles. Forgestar wheels are designed specifically for your car and it's suspension setup, where cast wheels are designed for everyone and typically do not take in to account lowered suspension setups.
Weights:
18x8.5 ET48 - 17.6 Lbs.
18x9.5 ET48 - 18.4 Lbs.
18x10 ET42 - 18.2 Lbs.
18x12 ET68 - 20.0 Lbs.
19x8.5 Approx weight 22.5 lbs !!
19x 9 approx weight 24.1 lbs
19x10 approx weight 24.7 lbs
Available Offsets and Sizes:
18x8.5 offsets from +26 to +50
18x9.0 offsets from +20 to +55
18x9.5 offsets from +26 to +60
18x10.0 offsets from +16 to +42
18x11.0 offsets from +23 to +55
18x12.0 offsets from +36 to +68
19x8.5 offsets from +26 to +48
19x9.0 offsets from +20 to +50
19x10 offsets from +20 to +45
19x11 offsets from +23 to +55
20×8.5 offsets from +26 to +50
20×9.0 offsets from +18 to +56
20×9.5 offsets from +7 to +43
20×10 offsets from +31 to +69
20×10.5 offsets from +20 to +55
20×11 offsets from +48 to +81
20×12 offsets from +39 to +75
They come in four available finishes: Brushed Titanium, Gunmetal, Gloss Black, Gold, and Custom Powder Coat Matte Black
Forgestar F14 Pictures:
Give me a call here at 714-582-3330 ext 8006, PM or email me at Alan@ModBargains.com if you have any questions!
Alan
Old Jul 9, 2010 | 04:08 PM
All pms sent and replied guys thanks!
Old Jul 14, 2010 | 03:05 PM
COBB Tuning
Jan 1, 2025 09:02 AM
COBB Tuning
Nov 9, 2015 08:02 PM
TrackOne
Aug 20, 2015 12:56 PM
ModBargains
Aug 20, 2015 12:28 PM
