GT3/GT2/GT Vendor Classifieds
:: ECS Tuning :: Exact Fit Stainless Steel Brake Lines | Do The Job Right.
Old May 21, 2013 | 01:38 PM
ECS Tuning - Porsche's Avatar
If you spend time and money renewing your brake hardware and linings, you ought to consider upgrading to ECS Tuning Exact-Fit brake hoses, and do the job right. These premium brake hoses are stronger, more durable, and better protected than the originals. They are shielded in stainless steel mesh reinforcement, and coated with bright red vinyl for added protection. Available by the axle for front or rear, or as a complete vehicle set, our DOT-approved, tailored hoses fit like OE for hassle-free installation.
Click Here for more information
Old May 31, 2013 | 03:26 PM
The best part about ECS Exact-Fit brake lines? They fit to your car exactly as they were intended, with no modifications necessary. They have also been approved by the Department of Transportation for highway use, having been tested up to pressures of 3000 psi.
Old Jun 10, 2013 | 03:00 PM
Additionally, exposure to the elements can cause rubber lines to soften and swell over time, increasing the potential for a soft, mushy brake pedal, or worse, complete failure. ECS Exact-Fit stainless reinforced lines, however, are coated in out signature red vinyl to provide protection from the elements, and prevent this type of failure.
Old Jul 3, 2013 | 08:46 AM
Even when new, factory style fabric mesh lined rubber hoses are prone to expansion under the pressure of hard braking, whether it be highway panic stops or threshold braking at the track. This expansion is even more prominent in aged and weathered rubber hoses. Our lines are braided with stainless steel mesh, affording expansion resistance. This resistance to expansion creates a firmer pedal, and more direct pedal feel.
Old Oct 24, 2013 | 02:59 PM
These tailored hoses fit like OE for hassle-free installation
Click Here for more information.
Old Oct 28, 2013 | 01:33 PM
gman3280's Avatar
gman3280 is infamous around these parts
I installed a set of lines, not this brand, yesterday on a BMW. The hardware was standard! I had to dig up standard wrenches and didn't have flares.
Do these install with metric wrenches?
Old Oct 28, 2013 | 03:25 PM
They do indeed install with metric (not sure of the exact fit off hand) wrenches. You shouldn't need anything out of the ordinary for the install.
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
Jun 10, 2017 07:45 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
HolmaN
Aug 18, 2015 01:35 PM
