BBi Autosport Porsche 991 GT3 StreetCup II Bolt-In Roll Bar
Now Available and Specifically Designed for 991 GT3 Models
The BBi Street Cup roll bar features a 2 piece design and 4130 chrome moly steel tubing (1.625" x 0.095) for excellent strength to weight ratio. With our sensible design approach, the 2 piece design mounts to frame structure, utilizing factory bolts, to provide strongest mounting points and maximum protection. For superior strength and rigidity, the bar utilizes "X" braces on both front and rear sections and each joint has been meticulously TIG welded by hand. Bolt-in installation is accomplished by using Inner Diameter Tube Clamps that are CNC turned and milled for a precise fit. These unique joints allow us to eliminate the more traditional slip fit tubes with an unsightly through-bolt and nut.
Features
International shipping is available and wholesale inquiries are welcomed. BBi Autosport products are also available worldwide through our growing dealer network in North America, Latin America, Europe, Middle East, Africa, Asia and Pacific. BBi Autosport is always actively working to expand our dealer network worldwide to grow the distribution of our products and better serve our growing client base. For all questions and inquiries, please email Jerry@BBiAutosport.com or Sales@BBiAutosport.com
Features
- 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
- TIG welded and utilizes "X" braces on front and rear sections for superior strength and rigidity
- Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock seats or any aftermarket seats on the market
- Allows full seat travel to accommodate taller drivers
- Can be used with stock seatbelts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
- Made in USA
BBiAutosport
GT3/GT2/GT Vendor Classifieds
Jan 8, 2018 10:22 AM
