How do you adjust the GT2 wing?
Old May 28, 2004 | 12:26 PM
Josh's Avatar
Josh is a jewel in the roughJosh is a jewel in the roughJosh is a jewel in the roughJosh is a jewel in the rough
I tried to search for information on this, but could not find anything.
How is this wing adjusted and is there some type of chart out there that shows what type of downforce is generated at the different pitches?
Old May 29, 2004 | 11:41 AM
Code Red's Avatar
Code Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to behold
It is realtively easy. There is a screw in the top of the palsic insert that you remove than the insert becomes removable. Underneath there is a large bolt to loosen. Lossen both sides at the same time , adjust the wing and reinstallthe inserts. As I remember, there is also a screw at the bottom that looks like it needs to be removed but actually doesn't. The one thing to watch out for is that it is VERY easy to drop the screw on he reinstall in which case you have to remove the plastic cover holding the fan and the screw is usually hiding in the very quarter of the body panel.
Good luck.
Old Jul 11, 2006 | 12:05 AM
stuka's Avatar
stuka is infamous around these parts
Anyone know the torque spec on the screws?
I would rather that the wing stays on my car at say, Button Willow...
Old Jul 12, 2006 | 11:23 PM
M3j0n's Avatar
M3j0n is infamous around these parts
very good question... if im not mistaken, i believe there are 3 pitch setttings for the stock wing. ANyone got pics of the wing in all 3 positions? thanks!!!!
Old Jul 13, 2006 | 08:28 AM
deardara's Avatar
deardara is infamous around these parts
Rockinc1
Sep 30, 2015 06:44 PM
John@SpeedTech
Sep 4, 2015 07:23 AM
