adjusting wing on RS ?
Old Jun 22, 2008 | 11:05 AM
smadja's Avatar
smadja is infamous around these parts
Does anyone know of any documentation or personal experience on how to adjust the wing on the RS?
I cannot figure it out...
help please :-)
Old Jun 22, 2008 | 08:53 PM
Daytonaviolet's Avatar
Daytonaviolet is infamous around these parts
its fairly simple. there are 4 rubber covers, 2 on each side of the underside of the CF blade along side of the decklid raisers. pop off those rubber covers with your finger nails or a plastic tip. under each cover there is a bolt. the two most forward bolts (facing the rear window) is the pivot points. the other two bolts will allow the wing to raise up. good luck
Old Jun 23, 2008 | 05:54 AM
sheim911rs's Avatar
sheim911rs has a spectacular aura aboutsheim911rs has a spectacular aura aboutsheim911rs has a spectacular aura about
the stock adjustment seems to be perfect for me at Road America, which is a long high speed track. If you want more particulars about the kind of course it is, just google it. Good luck
Old Jun 23, 2008 | 09:52 PM
mowblowgo's Avatar
mowblowgo is infamous around these parts
Pop the painted caps, loosen bolts, slide to adjust the angle, tighten bolts, replace painted caps. Unless you are doing 150mph+, and have added a front splitter, you will feel no difference with the aero of the car.
Old Jun 24, 2008 | 12:09 PM
painted caps? arent they usally just black rubber caps?
Old Jun 25, 2008 | 10:56 PM
mowblowgo's Avatar
Yes, black rubber caps.
ELMEL
Sep 28, 2015 01:12 PM
JWrightPNH
Sep 17, 2015 01:42 PM
davetherave
Bentley
Sep 16, 2015 06:30 AM
sparks
Sep 8, 2015 03:03 PM
