Custom GT3 Headers
Old Jan 13, 2009 | 10:25 PM
cjv's Avatar
cjv
Moderator
I should be getting the invoice tomorrow. I'll relay the cost then.
I just got an e-mail with the attached before and after dyno charts along with all info in 10 rpm increments. I can't seem to transfer them to my photobucket account and then to 6speed. I will try again tomorrow.
Old Jan 13, 2009 | 10:35 PM
GTS-R's Avatar
GTS-R is infamous around these parts
Originally Posted by cjv
Chuck,
They sound a little throater. On the dyno, they accounted for an additional 31 hp. The car was dyno'ed stock and then with headers only add. I can post the dyno sometime today.
Is that with the stock ECU settings?
Old Jan 13, 2009 | 10:57 PM
cjv's Avatar
cjv
Moderator
Yes, the ECU has not been touched.
Old Jan 14, 2009 | 11:44 AM
TSP-MIAMI's Avatar
TSP-MIAMI is infamous around these parts
Mark at * *** ** Racing built them. Mark has been with them for years and prior to that he was with Sanderson Headers. He really knows his headers and he is a fanatic when it comes to quality and design.
Chad is correct about Marks skill. Rob has always stood by the quality work of Marks. Have have used their stuff with great results of fit and performance.
Theo
Old Jan 14, 2009 | 02:43 PM
mobonic's Avatar
mobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud of
What's the difference say between these headers and say some Fabspeed headers?
Also what do you mean by catbypass headers?
Old Jan 14, 2009 | 02:44 PM
cjv's Avatar
cjv
Moderator
Old Jan 14, 2009 | 02:49 PM
cjv's Avatar
cjv
Moderator
Old Jan 14, 2009 | 02:52 PM
cjv's Avatar
cjv
Moderator
Old Jan 14, 2009 | 02:57 PM
TSP-MIAMI's Avatar
One visual difference is the merge collector section of the header and flange area.
Theo
Old Jan 14, 2009 | 04:31 PM
cjv's Avatar
cjv
Moderator
The merge collector is a big difference. Look at the merge point. They are not cut in ......... they are a true merge. A lot of labor goes into this design, Not knowing the type of material and it's thickness could be another. Not knowing the length of each run could be a third. I do not know what type of weld process the other headers use. Finally, I don't know if the others throw CEL or not.
I guess they would be hard to compare.
Old Jan 14, 2009 | 04:38 PM
cjv's Avatar
cjv
Moderator
Originally Posted by mike_shp
price?
$3,100.00
Old Jan 14, 2009 | 04:56 PM
Steve W's Avatar
Steve W is a jewel in the roughSteve W is a jewel in the roughSteve W is a jewel in the rough
Thanks. The results look great, although the delta shows 20 rwhp, (379-359). Assuming a 15% transmission loss comes to 23.5 hp gain at the motor. I'm surprised a CEL isn't thrown. The pre and post o2 sensor's are used to determine the health and efficiency of the cats. 993s with aftermarket 100 cell cats often eventually throw a CEL. Do you know what the reason was one of the O2 sensors is placed to read upstream at one of the primaries, instead of at the collector where it could read all three cylinders?
Old Jan 14, 2009 | 05:32 PM
cjv's Avatar
cjv
Moderator
Steve,
My calcs are off .......... sorry, I was repeating what I was told before I examined the sheets. Although 16% was being used, your numbers are correct. Thanks for the help. It does not throw a CEL. Remember, I said these are kat bypass headers. You are correct about the two sensors and what they do. If you put one sensor in precisely the correct location reading one cylinder and put the other in a location reading all three cylinders you fool the computer. No CEL. There is a bit of design in these headers.
Old Jan 14, 2009 | 05:40 PM
cjv's Avatar
cjv
Moderator
Originally Posted by 03-turbo911
With no side mufflers these will be pretty loud!
Beautiful work though.
What you are refering to as "no side mufflers" is actually no kats.
Old Jan 14, 2009 | 06:02 PM
cjv's Avatar
cjv
Moderator
