18" vs 19" wheels on 997 GT3
Old Jan 24, 2009 | 06:55 AM
ast78's Avatar
ast78 is infamous around these parts
Kinda new here but wanted to get some opinions on running 18" vs 19" wheels performance, looks, tech issues, etc.... Also anyone have pics of 997 GT3 with 18" wheels?
ast78
Old Jan 24, 2009 | 08:50 AM
sws1's Avatar
sws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of light
Serious track drivers will use 18". For street, I'd stick with 19".
Old Jan 24, 2009 | 08:53 AM
David9962000's Avatar
David9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond repute
CCW makes the C14's in 18" for the 997 GT3.
Old Jan 24, 2009 | 11:58 AM
ast78's Avatar
CCW's look pretty nice, also reasonably priced. Have any experience on the track with these?
Old Jan 24, 2009 | 01:33 PM
Laguna_Dude's Avatar
Laguna_Dude has a reputation beyond reputeLaguna_Dude has a reputation beyond reputeLaguna_Dude has a reputation beyond reputeLaguna_Dude has a reputation beyond reputeLaguna_Dude has a reputation beyond reputeLaguna_Dude has a reputation beyond reputeLaguna_Dude has a reputation beyond reputeLaguna_Dude has a reputation beyond reputeLaguna_Dude has a reputation beyond reputeLaguna_Dude has a reputation beyond reputeLaguna_Dude has a reputation beyond repute
I would go with the lightest & strongest 18" wheel you are willing to pay for. BBS (E88 or similar) or HRE (Cup Racing or "C" Series). Here's why:
1.) For same wheel, 18" will be marginally lighter than 19". Regardless, you want the lightest possible wheel, as this will give you an immediate performance boost from reduced unsprung weight: Better acceleration, braking and handling.
2.) 18" wheel will effectively increase the final drive ratio, improving acceleration in all gears. This is key, as the gearing in 3rd and 4th is a bit too long. I think it will shave a few 10th's of a second to 60mph.
3.) If you want to eventually move on to slicks for track, 18" offers best selection. However, more 19" options are becoming available.
4.) If you get 18", you should also, corner-balance, re-align (aggressive street will work) and lower the car as well. Another benefit is the car can be set lower on 18"s, lowering the center of gravity and improving handling as well.
Here are pics of my RS with 18" HRE Cup Racing Wheels:
http://www.gmgracing.com/dave_gt3rs.shtml
Same wheel as the GMG HRE Wheel, but offset/sized for the RS. The GMG HRE Cup is sized for the GT3.
Old Jan 24, 2009 | 03:06 PM
Brandon's Avatar
Brandon is infamous around these parts
you forgot 18 inch tires are cheaper. haha
Old Jan 24, 2009 | 05:27 PM
toadinlaw's Avatar
toadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud of
counter point. the 997 3 was designed for use with 19 inch wheels. the lower profile 19 inch wheel will have a different driving dynamic. Now I am not saying that the average person would take notice, and its true that you will have many more choices of rubber by going to 18. the 18 inch tire will be a bit smaller in diameter which gives you better acceleration, but depending on the track different shift points because of the smaller tire.
Old Jan 24, 2009 | 07:31 PM
mobonic's Avatar
mobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud of
what tire height do you use for your 18 wheels on 997 gt3.
Im going to be getting 18" for the track and I not sure if im supposed to keep the same profile height, or go bigger.
My current set up:
235/35/19
295/30/19
Old Jan 25, 2009 | 02:03 PM
toad, you can get the same profile on an 18" wheel. I would recommend it. All tracks are different, some require shorter gearing, others longer. The stock setup, IMO is a hair too long in 3 & 4. 1st and 2nd are perfect. The cars are raced with 18's. You have to remember, the GT3/RS are designed for racing and simply sold to meet racing requirements. The 19's IMO, were put on to follow the trend of larger wheels on street cars for the perceived "aggressive" look. Regardless, 18 or 19, go light. That's were the bulk of the performance boost comes from. The rest is minor. For me, major downside is that Michelin doesn't offer 18" PSC's in the sizes I need (they used to). They have a larger selection in 19". So I am forced to use Pirelli's, which, IMO, aren't as sticky.
mobonic, Pirelli Corsa's: 235/40/18 in front, 315/30/18 in rear. The front has slightly higher profile. This does "softens" the tire slightly, which improves front grip (fights understeer) and surprisingly has no noticeable loss of responsiveness/feel.
Old Jan 25, 2009 | 07:59 PM
OmahaGT's Avatar
OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !
Laguna,
Your RS looks great. Off topic, but who did your winshield decal?
Old Jan 25, 2009 | 08:51 PM
Thanks OmahaGT. I bought the car back in Sept. from Steve B. (he is a forum member) in San Diego. I believe he had it done at Stuttgart Performance in Costa Mesa, CA, but not 100% sure. I owe Steve a call and will confirm and post the details for you.
Old Jan 26, 2009 | 09:33 AM
ast78's Avatar
Laguna_Dude,
Thanks for the descriptive insight! Your wheels look great. I guess depending on how much i track i may just have to get a set of 18".
Old Jan 26, 2009 | 09:52 AM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
I agree.
Old Jan 26, 2009 | 10:23 AM
WheelB's Avatar
Site Sponsor
WheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant future
ast78
hey if you like pics i have done alot of Gt3 on 18" and 19" i can send your pics pm me your email address .. thanks ben
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest HRE Dealer In The World / Largest ANRKY Dealer / BBS Premium Dealer / TechArt Premium Dealer / Vorsteiner / Rotiform / Akrapovic / iPE / Novitec / Brabus / AC Schnitzer / Mansory / Brembo / RENNTech / Weistec / Tubi / Hamman / KW / H&R and tons more.
Old Jan 26, 2009 | 10:46 AM
grussell's Avatar
grussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud ofgrussell has much to be proud of
I currently have a GT3 RS and I had a GT3 and I have driven both cars on multiple whell and tire combos on the street and track. Without question, both cars drive and perform better on 18" wheels and tires. The 19's are for looks.
PelicanParts.com
997 Vendor Classifieds
Aug 20, 2015 02:39 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
PelicanParts.com
Aug 18, 2015 03:41 PM
