need front rotor replacement. anyone tried girodisc?
Glad you got the Girodisc on. Looks great. What was the weight difference if any. Oh, I notice a small dirt spec on the caliper
Man! Do you wax your brake caliper? I think you wash your car too often that is why there are more crack on the outside of the rotor lol
Those RS29 pads sit pretty close to the hat but you have enough space. It was a PITA having to modify the brake pads to fit Cup rotors.
The difference in beer color makes it easy to bleed your brakes ... no difference in alcohol content right?
Man! Do you wax your brake caliper? I think you wash your car too often that is why there are more crack on the outside of the rotor lolThose RS29 pads sit pretty close to the hat but you have enough space. It was a PITA having to modify the brake pads to fit Cup rotors.
my digital scale was out of battery so i had to settle for my analog scale which i'm certain might be off but fwiw the girodisc front rotor was roughly 2-3 lbs LIGHTER than oem steel. girodisc ~20.x lbs. used oem ~22.x lbs. i'm sure RSSbryan's numbers are more accurate than mines (post #47).
nice. if i can get 25+ days out of these then it's well worth the money over oem. i'll try to post feedback after i ring these out at laguna in a couple weeks. i'm pretty sure i can still outbrake mikymu with his 380mm cup rotors with these.
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
