997 GT3 on 20" COR Fossil's
Here are some pics of a 997 GT3 with 20" COR Fossil's
Finished in brushed aluminum centers with chrome lips and rivets.
20x9 - 2 inch lip
20x12 - 4 inch lip
20x9 - 2 inch lip
20x12 - 4 inch lip
Thanks for the compliment
Thanks, I can understand where you are coming from. However keep in mind this particular 20" wheel and tire setup is actually lighter by 3 pounds per corner as well as a wider rear contact patch (this car is running 325/25/20 Michellins in the rear)
Form AND function, very nice guys!
You guys need to post some track setups here and save this stuff for the turbo and 997/s section.
Thank you sir!
A lot of consumers don't take into consideration that just because a wheel setup might be bigger than 19" doesn't mean the wheel is a non functional heavy wheel setup.
Here is a picture of a raw center of our Cipher wheel with our Race Package.
This is a 20" center disc which will go into 21" step lips for a Nissan GT-R.
The total weight of the wheel once assembled is approximately 25.5lbs - for a 21" wheel
Now who wouldn't want their car to look good and be functional at the same time?
That's an easy answer. The owner of this expensive machine wanted those wheels for this particular car.
They actually spin while the car is moving
let me know when you want a set sir
