BBS on '10 RS
Old May 7, 2010 | 03:27 PM
rmag's Avatar
rmag is infamous around these parts
Originally Posted by 58spdstr
That's quite a sight (not to mention investment). Rains and dry?
All dry. Done driving in the rain ..not that much fun anymore ... and only bad things can happen!
Old May 7, 2010 | 05:10 PM
GT2Driver's Avatar
GT2Driver is infamous around these parts
How much is a set of those BBS for a 2010 GT3 RS?
Old May 7, 2010 | 05:24 PM
xXxGhotimanxXx's Avatar
xXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond repute
Love those wheels. They would be my choice. Do the tires come with the raised white letters? Did you put them on the inside? I think they would have completed the look.
J
Old May 7, 2010 | 05:28 PM
rmag's Avatar
5-6k per set depending on who you get them from.
J
Hoosiers have no white letters. Michelin slicks do.
Old May 7, 2010 | 05:33 PM
Ah. Thanks for the clarification. Car looks great. How much do those rims weigh compared to the stock rims?
J
Old May 7, 2010 | 05:42 PM
rmag's Avatar
J
Stock 19" wheel with MPSC:
Front: 43.9lb
Rear: 57.7lb
18" BBS with Hoosier 255/335
Front: 44.6lb
Rear: 52.0lb
-5.7lb rear, +.7lb Front
(measured on crappy scale)
Old May 7, 2010 | 06:55 PM
Wow, only -5 lbs. net? I would have thought that the weight savings would be more. Guess the stock rims are pretty light...Well, you still have the performance advantages of rim strength and increased tire sidewall with the 18"s.
J
Old May 7, 2010 | 07:29 PM
GT-Silver's Avatar
GT-Silver is infamous around these partsGT-Silver is infamous around these parts
I would to put these rims on my car, will these fit a 997 gt2 with pccb's ?
thanks
Old May 7, 2010 | 08:49 PM
Guest's Avatar
Guest is infamous around these parts
Question
Front: 43.9lb
Rear: 57.7lb
Front: 44.6lb
Rear: 52.0lb
Do they come in 19"?
Old May 8, 2010 | 05:28 AM
Condor Man's Avatar
Condor Man has much to be proud ofCondor Man has much to be proud ofCondor Man has much to be proud ofCondor Man has much to be proud ofCondor Man has much to be proud ofCondor Man has much to be proud ofCondor Man has much to be proud ofCondor Man has much to be proud of
Are they the same as the BBS 997 CUP Wheels??
Old May 8, 2010 | 05:47 AM
rmag's Avatar
thanks
they come in any offset yu need, just different rim halves. Not sure if they fit over PCCBs. Will be trying on friends RS who has PCCBs at some point.
Yes, but they still use 18" center with different rim halves, so look kinda funny. Pic below of a black one
Almost. Only difference is the center hole. More of a conical shape for the RS because it uses a different locking mechanism than the Cup. So not interchangeable.
Old May 8, 2010 | 05:51 AM
Condor Man's Avatar
That's a real Pig!!
I have 3 sets of the BBS for my cup!
Old May 8, 2010 | 10:44 AM
Mahzari's Avatar
Mahzari is infamous around these parts
What do the wider tires feel like compared to stock? Similar balance? More under/oversteer?
Old May 8, 2010 | 01:35 PM
atleung's Avatar
atleung is infamous around these partsatleung is infamous around these parts
If you find them missing in your garage, it's not me . I will be sporting my stock wheels and tires next week at Summit because the wheels I order ain't ready. See you there. Al
My pile arrived today
Old May 8, 2010 | 03:01 PM
rmag's Avatar
Al - You should swing by so we can see if the 18s" will fit on a PCCB car. Although a large deposit will be required before we fit them, just in case you decide to take off
