OEM GT3 lift
I don't see why not... though I expect it to be an expensive retrofit.
You'd probably be better off going aftermarket. Techart makes a nose-lift kit. It goes even higher than the oem giving you more obstacle clearance.
The OEM lift kit will be prohibitively expensive. However, if money is no object I say go for it. I've used both the OEM and the Techart one and found both to be about the same save for the, as mentioned before, increased clearance of the Techart unit.
Jul 29, 2019 11:13 AM
GixxerGino
Aug 26, 2015 06:42 AM
