996 GT3 Track Mod Advice
After two track days (Thunderhill and Infineon), it's becoming increasingly obvious that I need a few "extras" for the car. Based on feedback from many, I would like to pursue safety first and install a roll bar, seats, harness, and brakes.
Can Sharkwerks take care of this? Are the GT3 euro seats a "must" or is there a better alternative? I'm replacing the ceramics with steel. . . should I go with the GT3 cup rotors or a Brembo package? Thanks in advance for your help! |
Originally Posted by Mcgyver
(Post 3029100)
Can Sharkwerks take care of this? Are the GT3 euro seats a "must" or is there a better alternative? I'm replacing the ceramics with steel. . . should I go with the GT3 cup rotors or a Brembo package? Thanks in advance for your help! The Euro seat is great. however if you do not need the seat to be a folding one, I would consider a nice set of Recaro fixed back race seats. and an set of HANS approved harnesses. As for the brakes, We have been switching out the ceramics for the Brembo kits. And on the cup cars we actually do a 355mm AP rotor with a custom hat front and rear. The life of the Brembo and the AP are about 2.5 times greater then the factory cup rotors. Please feel free to contact me anytime for more information. Here is our Streetcup bar http://i414.photobucket.com/albums/p...%20Cup/062.jpg http://i414.photobucket.com/albums/p...%20Cup/047.jpg http://i414.photobucket.com/albums/p...%20Cup/025.jpg http://i414.photobucket.com/albums/p...%20Cup/110.jpg http://i414.photobucket.com/albums/p...%20Cup/118.jpg |
if you want off the shelf bar, sharky can do it for sure.
but you are in the bay area, if you want a real bar, contact tcdesignfab.com, they are 15 miles from sharky and alex knows tony. just ask alex, he will give you the same response. 996gt3 is the best "deal" though not the best seat. i prefer recaro elephant ear seat. once you add seat, bracket and slider, it;'s $3000 per seat. 6gt3 seats are 2000 or so used per PAIR, includes ALL hardware. you just bolt it in. really just bolt it in. zero mod. sharky can do it so is harness. get a HANS and use HANS harness. brakes, your front is direct swap for 996 cup rotors or deman rotors (very heavy, but for DE it's fine and will last you 3x longer than cup rotors). google deman rotor you shall find. rear is also 997 cup. there are other set up's but all cost more. shark can do all that. brembo, ap are all bee's knees, but $$$ |
I have the 996 Euro seats, and have tried the CGT, and 997 Sport Seats (GT2) and like the 996 ones the best.
If you are tracking a lot, I would suggest a slotted 2 piece rotor to replace your ceramics. I have Giro's, but the Brembo's are also a great choice (cost more though). As far as Sharkwerks goes, if I were near by, I wouldn't hesitate to use them. They have access to all the good stuff. |
As Mooty stated 997 Cup rear and Deman front. If you are really adverse to spending $$$ then these also work on the front. About same weight as Deman rotors.
http://www.pelicanparts.com/cgi-bin/...m%20Disc%20%20 http://www.pelicanparts.com/cgi-bin/...m%20Disc%20%20 I run them on the front of the 6GT3. ;) with no issues. Peter |
while you are talking to Tony at TCDesigns ask him about a corner balance and alignment and while in there consider adjustable droplinks to eliminate sway bar pre-load (makes it much easier to make adjustments at the track) and adjustable rear toe links with locking plates to eliminate loss of toe adjustment caused by the stock eccentrics
Thanks, Guys!
Christmas is, in fact, just around the corner. I'd say it's time Santa did some shopping. If you decide to do any Sharkwerks visits let me know. I can always use an excuse to gawk whatever may be sitting in their garage!
There are plenty of good shops in the bay area.
From pro level shops like TRG to independents. If you are near los gatos.. Try BRRacing What are you do decide to do, I recommend improving the driver and safety first. Than worry about go fast parts. We just a did a 996 GT3 track car for a client just search the forums we documented the entire build process. |
996TT safety solutions
4 Attachment(s)
We have done many of these for our Porsche clients in the Bay Area...and even had one unfortuneate situation that proves the need and value of the safety equipment.
One of our customers, who had a 996 GT3, rolled his car at Thunderhill coming out of turn 9....rolled it several times. He had the GMG roll bar / harness bar / shock brace / Sparco seats / full harnesses...and walked away without a scratch. We also have a couple of Porsche in our storage facility that have all the safety gear installed if you want to take a look at how the installation works, and how it completely bolts into the interior without any fuss or mess. We have a 996tt that is tracked regularly, and will attach some pics of that install here, and we are getting ready to do another 996tt for another customer. We also have our well know 2010 GT3 which also has the full compliment of safety gear. On our most recent install, the customers confidence and comfort from the harnesses and seats improved some much that his lap times dropped 2 seconds....with no other changes to the car. Let us know if you have any questions, happy to show you the options and optimal solutions. Can provide more pics if desired. We have done both Porsche seats, and Sparco race seats, both able to continue to use the stock seat belt harness as well for daily driving...alll sorts of options here. Attachment 136802 Attachment 136803 Attachment 136804 Attachment 136805 |
BRracing GT3 safety solution
We will also be at Thunderhill this coming Friday for the special Derric D tribute day and track day, with a large collection of our customers and our own GT3 if you are near or at the track that day.
Bruce BRracing |
(Post 3029100)
Can Sharkwerks take care of this? Are the GT3 euro seats a "must" or is there a better alternative? I'm replacing the ceramics with steel. . . should I go with the GT3 cup rotors or a Brembo package? Thanks in advance for your help! Having more supportive seats (buckets) and harnesses will keep you planted in them and safer too. Depending on what you want a) a bolt-in bar or b) indeed a safer/welded in bar from Tony you'd need to decide on that. I actually have one of the TCDesign (Tony) built roll bars in my 996GT3 if you want to see it etc... Next step try and check craigslist/ebay etc... for a set of 996GT3 european seats. They bolt right in without any fuss and are still somewhat comfy for driving to the track (I also have those in my 6gt3 if you want to see how you fit etc...) Suncoast might have a set of new ones for the best price (not sure). As far as brakes go I'd suggest a two piece steel replacement rotor (slotted) rather than ditching those already awesome calipers.... Something slotted and two piece will not only be a bit lighter but have improved cooling capabilities too so you can then also use a more aggressive pad if needed.
Originally Posted by Betim@BBIAutosport
(Post 3029112)
Safety first is a GOOD place to start. Sharkwerks would be a great place to get your cars safety up to snuff. They are an authorized installer of all BBI products. Here are a few pics of our Streetcup roll bar. Please let me know if you have any questions about pricing or want to see the bar in different cars or colors.
Originally Posted by mooty
(Post 3029130)
Originally Posted by NorthVan
(Post 3029133)
Originally Posted by GT3 Chuck
(Post 3029234)
Originally Posted by medpilot105
(Post 3030306)
Mcgyver,
Whatever you do, go to a shop that has extensive track prep and experience with these types of cars. A car being prepped for the track is not the same as a car being prepped for the street. Safety is the absolute first area to address, with a properly designed roll bar, 5-6 point harness and race seat.....from there you can start to address the other areas. Every time a new client walks into our shop asking us to upgrade his car for the track (our specialty), we always start with the safety equipment. From our Pro Racing support to our Club racers and track warriors, this matters most and then the performance upgrades start from there...... |
can i ask a really silly question (i think i know the answer)
why do people get rid of their CC brakes for track work? wouldnt CC's with their less unsprung weight make for a better drive? im assuming its just the cost of replacing the CC's? i'd prefer them for street driving LOL |
CC brakes for track use
Many reasons...as we have swapped out several sets of CC and gone to steel on our customers track cars, as well as we did it on our own 997.2 GT3.
- not a good selection of pad options - not a good feel on the track....and very temperature dependent - expense (for both pads and rotors) Even w the steel upgrades, we are seeing customers go thru rotors relatively quickly. No question of the weight savings....but you will see virtually everyone swapping out...and many have tried to make the CCs work, and eventually, there will be a proper set for track abuse. Bruce BRracing |
