997 GT3 TC Failure
Old Nov 11, 2010 | 10:39 AM
WickedToy's Avatar
WickedToy is infamous around these parts
997 GT3 TC Failure
Dear all,
i`ve got problem with TC in 997 GT3 2008.
If im driving for example on 2.500 rpms with constant speed, info message blinks up on dashboard and write TC Failure. I have to stop turn engine off, pull out key from the lock and start engine again. TC Failure is disapier then, but if i repeat the same driving constant speed, its blinks again.
Any experience from your side?
Old Nov 11, 2010 | 11:08 AM
10GT3's Avatar
10GT3 is infamous around these parts10GT3 is infamous around these parts
i have not had similar issue, however, should be warranty from dealer.
Old Nov 11, 2010 | 12:28 PM
axhoaxho's Avatar
axhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud of
Do you have factory wheels and tires on your car, and are all four tires the same make/model, size, and percentage of wear?
If there is any discrepancy among tires in the car, it might confuse the sensors of the traction control and cause the code...
Just a thought.
Regards,
Old Nov 11, 2010 | 02:33 PM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
Originally Posted by WickedToy
Dear all,
if your tires diameters are close to what they were supposed to be in stock version - you probably need to see your dealer or mechanic with PIWIS and get error codes analyzed.
Old Nov 11, 2010 | 02:50 PM
WickedToy's Avatar
Thanks for advice,
its orginal wheels of GT3 with michelin pilot sport cup tires as well, orginal dimensions. I was also thinking about sensors, maybe they dont read right dimension of tires (even the orginal tires and dimensions are on car), bla bla..Well i visit porsche service and get the answer after PIWIS coding and software update that the problem is with communication between TC modul and sensors - they want to rechange processor without warenty either i inform them over the email when the car got 11 months...hmmmm how yes no! Last information on the phone was that maybe they will not have to rechange it and will try some other option to do.
The biggest problem is that i live in small country and closes service is 160km from my home... and its not by the way to visit them for every "little" problem as im busy with work.
Old Nov 11, 2010 | 04:55 PM
mooty's Avatar
mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !
if your tire/wheel are orig. you probably hit a big bump or drove up a steel driveway with one wheel off the ground. when i do that, 50% of the time TC failure comes on. pull key out of ignition, reinsert it and it should go away. then that's pretty normal. i have 4 997.1gt3 variants, they all have that same characteristic.
Old Nov 12, 2010 | 12:21 AM
WickedToy's Avatar
my god, thats true. Sometimes when i hit steel driveway on highway it lights up. Well, i excatly do the thing you worte, reset it with key lock. I cant belive thats the issue they cant slove. Maybe its to sensitve? any Piwis coding against that?
Old Nov 12, 2010 | 08:26 AM
mooty's Avatar
not sure if PIWIS can fix it permanently. i think when certain wheel are lifted off ground under certain circumstances, the ECU is confused so it tells you TC failed and try to cut power to save the driver.... dont know.
it only happens to me on very lop sided driveways and always at speed lower than 5mph.
Old Nov 13, 2010 | 09:41 AM
WickedToy's Avatar
hmmm,
well, then TC is trying to save me every time i "jump" into the car :-) ha ha
I have to speak once again with guys from service, as they connect it on PIWIS and drive around, the problem was in losing communication between sensors and TC unit. I will update you when the problem will be hopefully slove!
Old Nov 16, 2010 | 07:40 PM
T.K's Avatar
T.K
T.K has a brilliant futureT.K has a brilliant futureT.K has a brilliant futureT.K has a brilliant futureT.K has a brilliant futureT.K has a brilliant futureT.K has a brilliant futureT.K has a brilliant futureT.K has a brilliant futureT.K has a brilliant futureT.K has a brilliant future
Doesn't turning ignition to II then back to III reset it?
Old Nov 17, 2010 | 01:43 AM
WickedToy's Avatar
Hej,
you mean to turnkey position to 1 - CONNTACT then back it left on 3 position? how much time i need to keep key in position 3?
thanks.
p.s. i was in service before 2 days and they changed switch on TC, and **** me i was happy 55 kilometers then TPC inactive pops up, minute after TC failour....god dammit i was so sad
Old Nov 17, 2010 | 07:31 PM
T.K's Avatar
T.K
Sorry.. I mean ON (driving state) to OFF. Memory is hazy as I now live in HK and haven't driven my GT3 for 4 months.. also, can't go to the car to check so not sure what the relevant ignition markings are [to be honest, I'm not sure if I've ever even paid much attention to my ignition barrel]!
Anyway, the basic principle is shutting down the car and restarting on the move using the clutch rather than the starter motor.
1) dip the clutch
2) ignition from ON to OFF,
3) leave for a few seconds (5 is plenty)
4) ignition from OFF to ON (i.e. back to driving state, not to engage starter motor)
5) pick up the clutch- car will restart
Don't do any funky **** like pulling the key out. You will crash. No need to use starter motor.
Generally going to OFF then ON resets the sensors so it should solve the TC issue and save you stopping every time you go over an expansion joint.
Should you have to do this on an 100,000 dollar + car? Different question! I do it when my ABS sensor packs in which happens sometimes if I brake hard on a bumpy road, and I used to do it when my oil pressure sender was on the blink. There may be someone along shortly to tell me it's not a good idea, but works for me and no issues.
Old Nov 18, 2010 | 02:32 AM
WickedToy's Avatar
Many thanks for your info, i will try it. Is there any beep sound after reseting?
Yes, you are right, thats ****ing things for car price i paid. Well, you are lucky as you are living in USA. Im from Europe, Croatia, and car costs me 194.000 eur which is around 230.000 usd...
I will let you know after i try the reset.
Old Nov 19, 2010 | 02:17 AM
T.K's Avatar
T.K
As for a reset beep, no, it shouldn't. Just beeps when it first flashes the warning, right?
Old Nov 19, 2010 | 02:27 AM
WickedToy's Avatar
That`s right. When warning light come out, it beeps. Ok, i still didnt try, hopefully today evening will do so.
pwdrhound
Aug 23, 2015 07:36 PM
PelicanParts.com
997 Vendor Classifieds
Aug 20, 2015 02:39 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
