Need help: Squeaky sound at the rear when going over slow bumps
Old May 15, 2012 | 09:27 PM
prodigue's Avatar
prodigue is infamous around these parts
Hi all,
I'm currently driving a 997.1 GT3 and I have been experiencing a squeaky sound coming from the rear when driving at slow speeds over humps and undulations. Suspension is stock and mileage is about 36,000km.
I brought it to my workshop and they re-greased the bushings on the anti-roll bar but the sound is still there. It doesn't happen at highway speeds.
What might be the cause? Can it be the dampers?
Pls help.. sound is driving me mad
Old May 15, 2012 | 10:22 PM
RAudi Driver's Avatar
RAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud of
Sounds like sway bar bushings but you say that they were just greased. I would start with the simple things first. Uninstall the bar, look over all the parts and reinstall. If it still squeaks, you can at least eliminate the bar as the culprit.
Dampers usually make a squishy sound when they go bad.
Old May 16, 2012 | 07:27 AM
Glock Guru's Avatar
Glock Guru is a splendid one to beholdGlock Guru is a splendid one to beholdGlock Guru is a splendid one to beholdGlock Guru is a splendid one to beholdGlock Guru is a splendid one to beholdGlock Guru is a splendid one to beholdGlock Guru is a splendid one to behold
+2 on the swaybar.
-Troy
Old May 17, 2012 | 10:42 PM
prodigue's Avatar
Thanks. Will get that re-checked.
What other rubber bushings are there in the rear section of the car? Would like to get all of them replaced.
audipwr1
Sep 25, 2021 01:31 PM
r_matt_6
Oct 8, 2015 06:07 PM
Zero911
Aug 24, 2015 06:51 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
