.1 and .2 sound
Old May 18, 2012 | 04:23 PM
Bryce86's Avatar
Bryce86 is infamous around these parts
.1 and .2 sound
All in stock form
is there a difference
Which is loudest
Sounds best
Etc
Thank you
Old May 26, 2012 | 11:01 PM
DrPeter's Avatar
DrPeter has a spectacular aura aboutDrPeter has a spectacular aura aboutDrPeter has a spectacular aura about
I too am curious. Having a 997 GT3.1, I feel it is a thrill for occasional use, but have found it is a little loud for a daily driver and it has a drone at a certain RPM.
Wondering if any one here has owned both and can compare their perception of the sound?
Old May 28, 2012 | 10:13 AM
Johnny DB's Avatar
Subscribed.
Old May 28, 2012 | 10:17 AM
RAudi Driver's Avatar
RAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud of
Dr Peter, don't tell me your car is stock. If so, then you need to get used to it as it's as quiet as it's going to get. I'm sure the .2 isn't any quieter. Most remove the rear center muffler for an even louder experience. I did this but am returning the car to stock this week. I too like the sound but sometimes it's a bit much.
Old May 28, 2012 | 11:40 PM
DrPeter's Avatar
OK, thanx for the reality check. The Cargraphic kit 3 with flapper valve is installed. I purchased the exhaust because the stock 3.5k RPM drone was killing me. Living 10 miles from work doesnt give me the opportunity to go to redline often and 3.5k RPM's is close to the speed limit for most of my ride.
However, as I remember, there did not seem to be that much difference in loudness with the Cargraphic flappers on quiet vs the stock exhaust. Guess, I have to find someone local with the stock exhaust to compare to.
Old May 30, 2012 | 07:55 AM
Doc_Porsche's Avatar
Doc_Porsche is infamous around these partsDoc_Porsche is infamous around these parts
I have the center delete, and always finding myself putting it in sport mode
Old May 30, 2012 | 11:36 AM
FooFighterRS4's Avatar
FooFighterRS4 is infamous around these parts
I've had both mk.I and mk.II GT3/GT3RS. Both had GMG bypass and driven almost exclusively in sport mode. The mk.II seems to have a deeper tone. Still has the typical Porsche high pitch but not as high as the mk.I. My hearing isnt the best so ymmv.
shiftmechanism
Nov 23, 2016 09:02 PM
pwdrhound
Sep 13, 2016 10:44 AM
Feelgood MD
Mar 24, 2016 09:35 AM
cm09578
Sep 10, 2015 05:26 AM
al3656
Sep 7, 2015 06:35 PM
