2007 GT3 clutch chatter
Old Jul 27, 2012 | 06:19 AM
LAPNYOU's Avatar
LAPNYOU is infamous around these parts
Question 2007 GT3 clutch chatter
Hello! This is my first post here. So be nice.
I bought a 2007 GT3 in Sept. 2011 with 14k and I've put another 10k on her and unfortunely because of my inexperience (i think) with a high powered manual i've apparently managed to wear out my clutch prematurely. I'm getting shuttering/chatter when letting the clutch out. I hope i've learned form my inexperience and can move on to more good times from now on. I've never had this problem with any manual transmission car/bike I've operated before including my '05 CBR1000RR which I track and street.
My question is relating to repair cost/quality. If I bring my GT3 to a nor cal dealer what should I expect to have to pay in the way of hours of labour and parts?
Also any suggestions as to good, honest, quality shops in the Sacramento, CA area would be welcome. And should I replace with stock or is there a better option?
Old Jul 27, 2012 | 09:58 PM
bumperpip's Avatar
bumperpip is infamous around these parts
In norcal, see Sharkwerks. Don't worry be happy.
Old Jul 28, 2012 | 03:11 AM
tredirtyfive's Avatar
tredirtyfive is infamous around these parts
upgrade with 4.0 pp & clutch. look for heat spots on flywheel,clutch, and pp. most likely the chatter is from excessive heat spots.
hope that helps gl
Old Jul 28, 2012 | 03:12 AM
btw, does it getting worse when u put in reverse?
Old Jul 28, 2012 | 11:31 AM
LAPNYOU's Avatar
Shutter to think
Yes reverse is a bit more sketchy than first.
Who makes the parts you recommended for replacement. And thank you for the reply. I appreciate the help.
Old Jul 28, 2012 | 05:30 PM
suncoast has repair kit
http://www.suncoastparts.com/product...Code=RS40TRANS
also check on the flywheel
COBB Tuning
Jan 1, 2025 09:02 AM
audipwr1
Sep 25, 2021 01:31 PM
RallyBird
Oct 7, 2015 01:20 PM
MrNurse
Sep 10, 2015 09:44 AM
JMon
Aug 21, 2015 08:20 AM
