18" track wheel advice
Old May 14, 2014 | 09:04 AM
gt3forever's Avatar
gt3forever is infamous around these parts
I was wondering if a set of 18" wheels with the following offset fits on 997.1 GT3 without any fitment issues.
Front: 18*8.5 ET 44
Rear: 18*10 ET 50
Additionally, what is the best 18" track wheel offest without spacers?
Thank you for your help in advance.
Old May 15, 2014 | 07:19 AM
RedRSA's Avatar
RedRSA is infamous around these parts
Stock 997.1 GT3 is 8.5" w/53mm offset front, and 12" w/63mm offset rear (net, i.e., including the 5mm spacer). As you can see, the cited specs would not work well.
Wheel diameter has little/nothing to do with offset; wheel width does. Most wheel manufacturers I spoke with use 63mm rear offset for a 12" rear wheel. That said, I still use a 5mm spacer, so 58mm will work fine without spacer.
Old May 17, 2014 | 08:38 AM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Front: 18*8.5 ET 44
Rear: 18*10 ET 50
NO!!!! wrong width and offset
for 18" you need:
8.5x18 et53
or
9x18 et50
12x18 et63
Old May 18, 2014 | 12:52 PM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
Originally Posted by mdrums
NO!!!! wrong width and offset for 18" you need: 8.5x18 et53 or 9x18 et50 12x18 et63
Correct- the 9" work great up front. I just ordered that config from CCW and am very satisfied.
Old May 19, 2014 | 07:56 AM
gt3forever's Avatar
thanks for your help guys. it was very helpful
COBB Tuning
Jan 1, 2025 09:02 AM
pwdrhound
Aug 20, 2015 05:54 AM
